ahurst
Why buy a Genesis now with 6-speed if they will offer an 8-speed auto in the 2010 model?
I think the V6 transmission is excellent. When I heard that the Genesis used an Aisin (V6) or ZF transmission (for V8), that made my buying decision a lot easier. It is not simple for a economy car company to come up with a sophisticated high-end and reliable transmission in a short time if they haver to design and manufacture it themselves.Better to lease than buy. The lease is only 2 years long. The current transmission on the V8 is fine. People complain about the ride not the transmission and they may not fix that until the new body style arrives.
Both transmissions have 2 over-drive gears for better gas mileage. Engines that powerful can support very high gear ratios, which is one reason the Genesis has pretty good gas mileage for a car of its size. 6 speeds is not too many IMO, for the Hyundai Genesis.Ditto to what scottdk said.
As it is, 6 speeds in an automatic are already two more than needed. The more gears in the transmission, the more the car lingers in the lower gears. When top gear in an
8 speed, or a 6 speed, or even a 4 speed is the same ratio, all the extra gears do is to stay in the lower gears longer. IMHO.
Where are these 2010 specs coming from. Is there anything else that"ll be different in the 2010 genesis?
That's one way to do it. Another way is to not use a lead foot.I agree Mark_888. But if they added paddle shifters I wouldn't mind the 8 gears. Wouldn't revs stay at a minimum in an only automatic trany with 8 gears?
Reliability is 100 times more important to me than all that other stuff, especially with regard to a transmission.
With regard to fuel mileage, once you reach cruising speed and your tanny torque converter locks up in highest gear, I don't think there is any additional benefit to having more gears. If I am wrong, please correct me.
Whoa, Nellie!!! (or Wally)You are both right and wrong, many transmissions now come with multiple overdrive transmissions, the ZF has 2, the final gear is 0.59:1 which is very very tall, with 5th gear still an over drive gear 0.72:1 . Not that long ago a trans would have 1 overdrive gear more in the 0.89 to .075 range. If you didn't have the extra gearing it would be quite a step from 4th (1:1) to .59:1
that final drive ratio is also why you can get 30 in the V8 on flat highways at 60 MPH.
