Windshield Wipers
Sarge101st
43
Sarasota
Just a little review. I love the project farm videos on Youtube. I feel that the guy running the channel does thorough reviews replicating real world scenarios and considers multiple factors to the items he's testing.
I recently watched the video on wiper blades he did and the Michelin Endurance XT (a Walmart exclusive,) came out on top so I bought the blades and gave them a try. Unfortunately after all I tried there was too much streaking and squealing on my windshield from them. I've always used the PIAA Si-tech blades purchased on Amazon and they're always perfectly quiet and consistent. Unfortunately the Michelin blades were the opposite. I won't even try out the new RainX Advantedge blades at Autozone since I have always had consistently good luck with the PIAA blades.
On a side note. I clean my windshield with an terry pad on an orbital buffer with glass cleaner. Swap out the pad for a fresh one and apply RainX with the buffer. Wipe off RainX with a microfiber cloth and then I apply a second layer of ceramic coating. The windshield glass is smooth as can be without sanding down the glass so I know it's not my windshield causing the issue with the Michelin blades as I swapped and immediately had perfection from the PIAA blades.
EdP
Supporting Member
SUPPORTING MEMBER
7,761
4,049
Parrish, FL
Glass cleaner, RainX, then ceramic coating? Seems a bit much on a piece of glass. What does all of that do that plain old Windex does when you hit some bugs? Tried RainX years ago and did not like the results. RainX blades did work well though.
TinsleyC
1,420
589
Dallas, TX
I tried RainX last spring and honestly, I can't say I noticed much difference. The water did bead off, but I still had to use the wipers anyway.
I've tried after market wiper blades / arms and end up going back to OEM. They just look and fit better.
skipgen
384
63
I've used Rain X silicone blades for years - they seem to clear better & last half again as long.
TinsleyC
1,420
589
Dallas, TX
So just the insert / blade - not the whole arm. They fit okay I assume?
TinsleyC
1,420
589
Dallas, TX
I think OEM wipers look the best. Been back and forth with that situation. Currently running OEM and when the wear out I'm going to just replace the blades and see how that works.
That's what I'm getting at. The blade does the work, the arm is what we see. I can see using third party blade refills, but not arms.
jimbrown618
17
Halifax, NS Canada
Michelin wipers from Costco....were $9.95 each.....seemed to work ok and cheap enough to change every 6 months :)
I also have a set of Bosch Icons that I received from a friend but haven't installed yet...pricey blades to buy though
carguy75
702
Atlanta, Georgia
I use Bosch Icon wipers blades with great results. My blades are about two years old and work well without any noticeable noises and skipping issues. The Icon wiper blades work like a person sitting on my hood using a squeegee to wipe the windshield during the rain. Damn good wiper blades.
jimbrown618
17
Halifax, NS Canada
Yes, I've had good luck with them on other vehicles prior to this one...I'll be putting them on for the winter soon...
carguy75
702
Atlanta, Georgia
I have been using the Icons for about 15 years on various cars and they work well until I traded the cars. I never had to replace a set on the same car as of yet. They also work well to remove ice and snow off the windshield without ripping apart like cheaper blades that I used before. Quality product for sure.
I am not sure if they are the best wiper blades available, but i know that they are reliable and perform as expected for a long time. Good enough for me.
SuperKing
151
43
Vancouver, BC
I only replaced my inserts once. PIAA/silicone blades last like 3-5 years depending on where you live. I installed mine in early 2016 and are only now starting to streak. I tried all sorts of full frame wipers with my Sonata and results were always the same. They start to skip within a few weeks, never really quiet and they really chatter at 90+kph. That's why I opted to keep the OEM frame and replace the blade insert with the Genesis. It was designed to fit the car properly. I was willing to do this once a year or so but it's been 4 and they're still good.
It also rains like 10 months of the year here.
2for1
22
va
Any wiper should perform well if the windshield is cleaned periodically of the road grime and that forms on the surface.
Windex wont do it. Needs a mild abrasive to do the job. I use Bon Ami once or twice a year.
I know people that use 000 steel wool.
Denso Hybrid blades work good for me. I used Bosch for years and they work good also.
TinsleyC
1,420
589
Dallas, TX
I stopped replacing just the rubber blades long ago. I replace whole frame with blade now. The Rain X Expert Fit looks nice and clean, not like the old school blades from decades ago.
That's the part I replace as well, I never could get just the blade right, they fit wrong or were too long or short. I like the OEM look of the original and that's why I've just bought the OEM replacement. But if you're saying the RainX Expert Fit looks good, I'll give it a try.
SuperKing
151
43
Vancouver, BC
PMCErnie
Been here a long time....
4,204
462
83
Richmond, VA
Seems like a lot of work just to get the surface as smooth as...glass.
