Genesis Forum: ABS brake module failed
Results 1 to 11 of 11
  1. #1
    martyk is offline Registered Member What I drive: Genesis 4.6 V8 Tau Sedan
    Join Date
    Aug 2011
    Posts
    131
    Rep Power
    7
    Default ABS brake module failed
    Members don't see this ad
    My ABS brake module failed on Tuesday afternoon. I had very little braking power, pedal goes to the floor. I bought it to the dealer and they said the brake module needs to be replaced. The service guy said they have to have it inspected by Hyundai warranty people to get it approved because I have the extended warranty and the price would be about $2,300 to fix.
    I bought the Genesis in Oct. 2011 new. It is a 2012 with 32,789 miles.
    Marty
  2. #2
    Gunkk's Avatar
    Gunkk is offline Registered Member What I drive: 1G Genesis Sedan (2009-2014)
    I live in Florida
    Join Date
    Oct 2011
    Posts
    1,132
    Rep Power
    Default Re: ABS brake module failed
    I just had mine replaced last week under warranty. Took them a week due to a 2 day delay waiting on warranty co. approval. Offered a loaner but I drove my Camaro for a few days instead
    $2477 cost to the warranty/insurance co. My cost: $0.
    https://genesisowners.com/hyundai-ge...Module-Failure
    '12 4.6 Platinum/Black
    Retired: '09 4.6 Tech Titanium/Black
  3. #3
    Youseethefight is offline Registered Member What I drive: Genesis 5.0 V8 R-Spec Sedan
    I live in Ft. Lauderdale, Florida
    Join Date
    Sep 2014
    Age
    31
    Posts
    230
    Rep Power
    4
    same problem happened to me extended warranty took care of it.
  4. #4
    vast is offline Registered Member What I drive: Genesis 5.0 V8 R-Spec Sedan
    I live in Raleigh NC
    Join Date
    Jan 2014
    Age
    39
    Posts
    47
    Rep Power
    Do you know if the ABS Module also controls the traction control? The other day my transaction control kicked on and after that my brake pedal goes to the floor before it grabs.
    2012 R-Spec 5.0 Black
    Painted grill gloss black. Painted rear chrome trim black.
    wheels: 20x8.5 20x10 Niche M157 Charcoal
    offsets: 35mm / 40mm
    tires: Nitto NT-555 Front: 245/35/20 Rear: 275/30/20
    intake: R2C
    exhaust: Borla XS Pro Mufflers
    Wheelwell
  5. #5
    Gunkk's Avatar
    I live in Florida
    Join Date
    Oct 2011
    Posts
    1,132
    Rep Power
    Stability Control yes for sure it uses the ABS.
    Traction Control: probably. Most modern cars retard timing and cut throttle reduce rear wheel torque, bogging the engine. The early 2012 5.0 was notorious for bogging while mashing the gas while turning out into traffic, to the point where HMA issued a TSB and had ECU/TCUs reprogrammed (but that was as much a SC thing as a TC thing). I'll bet the Genesis also uses the brakes as well to help transfer torque if one of the rear wheels is spinning (snow, ice, etc.). Not sure, don't get that around here too often
    If you still have a soft pedal, get it looked at.
  6. #6
    JerryB52 is offline Hasn't posted much yet... What I drive: 2013 3.8L Sedan
    I live in Ormond Beach, Florida
    Join Date
    Jul 2017
    Age
    65
    Posts
    19
    Rep Power
    I've had some problems with my braking also. But, instead of the pedal going to the floor mine stays at the top and doesn't seem to be engaging the brake. This has happened 2 or 3 times.
    I took it to the dealership and they said they couldn't find a problem and charged me $80. (At least they changed the oil.)
    My warranty is long gone and don't have the extended. Is this something that I can fix?
  7. #7
    Gunkk's Avatar
    I live in Florida
    Join Date
    Oct 2011
    Posts
    1,132
    Rep Power
    A firm pedal and no brakes (like a vacuum booster is leaking or has no vacuum) is not something I've experienced on this car.
    Quote Originally Posted by JerryB52 View Post
    Not unless you have a computer interface and a brake fluid flushing/bleeding machine.
  8. #8
    Join Date
    Aug 2011
    Posts
    131
    Rep Power
    7
    Just pick up my Genesis after 8 days to replace my ABS brake module. The bill:
    Hydraulic Module 2,087.31
    DOT Brake Fluid: 5.00
    Labor: 225.00
    Calif. Tax: 151.70
    Total: 2,469.01
    Marty
  9. #9
    Mcc is offline Supporting Member What I drive: 2017 Genesis G90 Ultimate
    I live in Los Angeles
    Join Date
    May 2017
    Posts
    329
    Rep Power
    Quote Originally Posted by martyk View Post
    Labor: 225.00
    Calif. Tax: 151.70
    Total: 2,469.01
    Marty
    And can we assume your warranty covered all of that?
  10. #10
    Mark_888 is offline Registered Member What I drive: 1G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2009
    Posts
    11,948
    Rep Power
    20
    Quote Originally Posted by Mcc View Post
    Not unless he had an extended warranty. The HECU unit is covered by the normal 5 year - 60K warranty. Since his forum join date is Aug 2011, I am guessing that his regular warranty has expired.
  11. #11
    Join Date
    Aug 2011
    Posts
    131
    Rep Power
    7
    YES. I have the extended warranty. See my posting above on 12/6/17. Marty
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
