Genesis Forum: Alloy wheel corrosion
Results 1 to 4 of 4
  1. #1
    nickpike's Avatar
    nickpike is offline Registered Member What I drive: 2G Genesis 3.8 V6 Sedan
    I live in UK
    Join Date
    Dec 2015
    Age
    67
    Posts
    212
    Rep Power
    Default Alloy wheel corrosion
    Members don't see this ad
    Hi, my rear alloy wheels are corroding, from the inside edge of the spokes. I'm hoping I can get them replaced under Warranty.
    Anyone else have this, and were they replaced?
  2. #2
    Mark_888 is online now Registered Member What I drive: 1G Genesis 3.8 V6 Sedan
    Join Date
    Jan 2009
    Posts
    12,269
    Rep Power
    22
    Default Re: Alloy wheel corrosion
    Posting some pictures would be helpful.
  3. #3
    EdP is online now Supporting Member What I drive: G80 AWD Ultimate Adriatic Blue
    I live in CT
    Join Date
    Jul 2017
    Posts
    726
    Rep Power
    Rears corroding but front ok? Have you tried removing it to see it is corrosion and not some strange coating buildup? Most can be cleaned by rubbing with crumpled aluminum foil and Coke, then a wax or protective coating.
  4. #4
    nickpike's Avatar
    I live in UK
    Join Date
    Dec 2015
    Age
    67
    Posts
    212
    Rep Power
    Quote Originally Posted by EdP View Post
    It's definitely a removal of the paint layer. The dealer says that other cars here in the UK have had the same problem and is covered under warranty. It's booked-in for inspection so I'll let them remove all four wheels and inspect them.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
