You cold do this... assuming you don't care for the "stanced" or "stretched" look....
265/35/20 up front running the 20x9 +32
295/30/20 in the rear running the 20x10.5 with a +22
Both of these would clear provided you rolled the rear fenders and took time to double check everything. There's always room to run more agressive offsets / setups with the understanding that the role this plays on your wheel bearings, tire life, suspension etc.
Rims and tires has a great calculator that I highly recommend if you plan on doing any type of custom setup -- staggered or not.
http://www.rimsntires.com/specs.jsp
Those tire sizes you listed would really throw off your gearing, stearing ratio, and a number of other things.
If you want the stretched look may I suggest 225/35 up front and 265/30 out back. This will keep the rotations about the same front and rear.
265/35 in the rear would be a slight stretch if you go with a 20x10.5 -5 to achieve the look / stretch accounting for the fact that you'll be rolling the fenders.
How aggressive? Are you willing to roll the fenders?
If you want the stretched look may I suggest 225/35 up front and 265/30 out back. This will keep the rotations about the same front and rear. You can play with your offset from there. Use the +32 as your starting point with OEM flush fitment. If your getting coils I recommend installing the coils first, check your clearances, then pick the rims. Clearance, and setup will change once your dropped.
The 225/40 would not be considered a stretched up front. Drop down to a 20x8.5 with a +30 on OEM and you'll be able to achieve that. 265/35 in the rear would be a slight stretch if you go with a 20x10.5 -5 to achieve the look / stretch accounting for the fact that you'll be rolling the fenders.
