6,000 miles and I am told I need a new engine. Dealership states there was not enough oil in the engine when I bought it. However, the oil light never came on so I never knew. Should I just demand a new car?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Another reason to not get oil changes at a dealer.
I am of the opposite opinion; if the Dealer is the only one who has ever worked on the car, then who is at fault, and what leg do they have to stand on to not cover any issues?
Any new car should get a PDI (Pre-delivery inspection), and they obviously failed to perform that. I have the PDI sheet from my car, and if any issues such as this should arise, guess who I am going to hold liable?
I have been on other automotive forums where this also happened (dealer mechanic emptied oil but forgot to add new oil or did not add correct amount using the overhead tanks and not individual bottles). In these other cases, the dealer denied that they caused the problem and claimed that someone else caused it. It is easy to prove that someone worked on a car, but harder to prove that no one worked on a car.I am of the opposite opinion; if the Dealer is the only one who has ever worked on the car, then who is at fault, and what leg do they have to stand on to not cover any issues?
Lemon laws deal with the specified time it takes to repair the car (cannot exceed a certain time frame or cumulative number of days where customer is without the car for a major issue that makes car undriveable or unsafe). If the dealer could install a brand new engine within the Lemon Law time limits, the Lemon Law remedies cannot legally be invoked.Most states have what is called a lemon law. Check with your lawyer and do not have any further correspondence with the dealer. Your lawyer will write the dealer and Hyundai and the consumer protection bureau in your state.
You will have a new car within 30 days. Bank on it.
This case may be different if car only had 6000 miles on it. We don't know if the oil had ever been changed.
I agree with your sentiments, however, dealers have been known to not stand behind their mistakes and to blame others. While one may prevail in court or in arbitration, a dealer can make one's life miserable in the meantime if and when such mistakes occur at a dealer (although I don't know what happened to OP)."Claiming" someone else caused it is world's apart from proving someone else caused it. The burden of proof would be on the Dealer. Just because they say something, does not make it true.
As per Hyundai, the oil would not need to be changed prior to 6000 miles. If this is the case, and it in fact had never been changed after new car delivery, then the OP has no liability given the circumstances.
Maybe it would be useful for to explain the exact time-line of events. It now sounds like you had no symptoms or problems, and took it in (or they picked it up) for an oil change and dealer told you engine is damaged because not enough oil in crankcase?All:
I just want to thank all of you for the input. Just to clarify, my car was running great. No lights, smoke and was not running hot.
This was to be my first oil change per the mantinence schedule.
Was told that someone from the Regional Office of Hyundai would get back to me today or tomorrow.
Will let you know as to what the resolution is.
Thanks again.
