Hello everyone,
Please do not post anything negative in the post. If you have a strong opinion, please start your own rant thread. Thank you.
I have found Megan Coilovers to be perfect for a Bag over Coil set up.
Since Megan coilovers have an integrated top mount you can slip over an air bag in place of the spring.
Also the ride can be somewhat decent since it has adjustable damping.
And using these threaded brackets from ForjWorks, the coilover can become this:
Can the damper adjuster location be rotated so that it is easily accessible with the wheel off?
Can someone take a picture of the rear lower control arm where the spring should sit. And a pic where the spring is on the body. I want to see how brackets should be made so you can run the air line to the rear bag.
Thanks,
I will worry about management later.
Thanks,
