GarciafactoryUS
- Jul 26, 2012
How low does the rear go?
EDIT: picture relinked...
here is few shots that i took this morning with my phone.
Height range looks good. Even drop when all the way down. You take these before you got your wheels? Or you take them off for the winter. When you put rims back on I'd love to see what the bags look like installed.
looks good, deff would like to see install/build pics.
its not really off looking when you see it in person. although type 1 front lip is better looking personally but it as never made for production. they made type 2 little different. also side skirts and rear bumper do flow pretty good. i really dont like box looking bodykit on modern bodylines it makes the car and bodykit looks not belong together although this type 2 front lip wasn't my first choice but only thing that was available so i had no choice.. also planning to put somevip style muffler on the back of the car which will show a little bit on the bottom of the muffler. theydo have full kit but im not going for it. but for older models 09~11 there is more full kit available then 2012.Front lip looks out of place / off.... even though you have different side skirts. Rear bumper is much higher which doesn't complete the package. Do you have anything planned for the rear?
our bolt on airsuspension uses D-cup systems as well. mine works fine and no cutting needed bolts right up and no problems so far.
Can you post a link to your system?
Almost positive he is running their Universal System after chatting with him a few times. Correct me if I am wrong GarciafactoryUS
you can seesome picture here
www.garciafactory.com
www.facebook.com/garciafactory
im using garcia factory's airforce universal with accuair right now. accuair was great management system but im replacing it with something else with more options like height and pressure control together with monitor that tells me more info.
Does the airforce universal kit require coilovers do be able to go as low as your car is?
^ How do those air systems ride? I am not looking for it to ride any sportier. I am looking for a luxury ride with the ability to lower her when I park....[/QUOT]
its 36 way adjustable coil. as of nowmine is at 36 in front and 30 in the back. slightly stiff then stock even if i put 20 inch. but handles much better. so you can go much softer if you want.
