danrstevens
I have a 2013 2.0T base,automatic transmission. Took it to the track with Driver's Edge Performance Driving school this last weekend and the 3.1 mile Motor Sport Ranch track in Cresson Texas. Tight track, 16 turns - though there are a couple of spots where you can exceed 100mph - great fun and excellent instruction. The car was great and held it's own very well. However, near the end of my 6th run (about 23 minutes each, with an hour or two between runs). I frothed/boiled some transmission fluid. It vented and looked like a huge cloud of smoke coming out of the bottom of the car. So I sat out the last two runs not wanting to damage the car (it seems fine so far, no leaks, shifts fine). Has anyone upgraded to a high temperature transmission fluid? Wondering what is out there that is compatible in case I go again, I do NOT want to add a cooler. I did flush the brakes and upgrade the brake fluid before I went and had no brake problems at all, even without Brembos or upgraded pads (none available, I checked).
