Itronics ITB-100HD Car Camera / Black Box Installation
Ruissimo
Hey there!
On December 22nd, I ordered myself one of these babies.
Got it last night, and made an unboxing video:
[ame="http://www.youtube.com/watch?v=_6EtFxgVsZE"]Itronics ITB-100HD Car Camera / Black Box UNBOXING VIDEO - YouTube[/ame]
Hope to get some good shots of the install, and after. And then, of course... some riding videos!
Re: Itronics ITB-100HD Car Camera / Black Box Install (in progress)
INSTALLATION DETAILS:
Materials Needed: One (1) Itronics ITB-100HD Unit with Power Cable and Mount, One (1) Mini Blade Fuse Add-a-Circuit (also known as ATM Fuse Tap), One (1) Additional Mini Blade 10 Amp Fuse
Tools Needed: Wire Crimper/Stripper, Flat-Head Screwdriver, LED Flashlight, Paper Towels, Some Patience
Time Required: Approximately 1 Hour with 2 People or ~ 2 Hours Solo
1) Clean installation area with glass wipe. Ensure glass is dry. Best done when glass is not cold (hint, a hairdryer can warm the area up as needed).
2) Place mount behind rearview mirror. Affix to windshield.
3) Attach ITB-100HD unit to mount.
4) Using crimper, cut Cigarette Lighter Adapter cord - leave a couple of inches at the end for future re-attachment (if needed - see pic).
picture.php
5) Attach cut wire to ITB-100HD unit; run wire up to top of windshield in middle of rearview mirror; thread wire underneath plastic cover. See pic.
picture.php
6) Run wire across top of windshield, tucking it into headliner neatly.
7) Using a flat-head screwdriver and a paper towel, carefully lift pillar cover and tuck in wire, running it across the top and to the right, until it meets the rubber strip. Then, run wire under rubber strip all the way to fuse panel outer cover. See pic.
picture.php
8) I removed the small fuse panel cover, then CAREFULLY removed the outer cover as well. Be careful not to break the clips that hold to the dashboard! See pic.
picture.php
9) Tuck wire from rubber strip down into fuse panel. Small or thin hands are useful in grabbing the wire once it is in the panel.
10) Strip wire outer cover. Strip red and black wires - careful not to break the thin wires inside.
11) Fold red wire over and twist, then insert it into Fuse Tap/Add-a-Circuit and using crimper, crimp the connection. Pull test lets you know it's a solid connection. (NOTE - soldering is probably a better connection, but I didn't go that route).
12) Connect black wire to ground - I used the bolt on the right side of the panel (not shown in pics, but it's there if you remove the outer panel cover).
13) Pick a fuse to tap into. Here's the one I used (which turns on with the ignition):
picture.php
14) Remove fuse using fuse-removal tool, which can be found in the passenger side fuse panel. Plug fuse into add-a-circuit. Add an additional 10-amp fuse to the add-a-circuit. Make sure fuses are pushed all the way in.
15) Plug add-a-circuit to the same location from which the fuse was pulled. See pic.
picture.php
16) Turn ignition on, and test unit. If it beeps, you're good to go.
17) Re-attach outer fuse panel cover. Tuck in all wires into fuse panel. Close fuse panel.
18) See pictures of the install:
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
Sorry for the quality of the exterior shots... got some really weird lighting outside today!
Oh, and here's a quick snapshot of what the software looks like (click to enlarge):
POST-INSTALL VIDEOS:
[ame="http://www.youtube.com/watch?v=INDy9_DqIec"]Itronics ITB-100HD - Daytime recording, light drizzle - YouTube[/ame][ame="http://www.youtube.com/watch?v=X4A50204_rE"]Itronics ITB-100HD - Daytime recording, light drizzle - YouTube[/ame][ame="http://www.youtube.com/watch?v=fjUP9Aaw_sA"]Itronics ITB-100HD - Dawn recording, light drizzle - YouTube[/ame][ame="http://www.youtube.com/watch?v=RO5Rjk1OrRk"]Itronics ITB-100HD - Night time recording, light drizzle - YouTube[/ame]
Taken this morning in Sandy Hook, Newtown, CT. Quick useless fact #1: The location in the first video is on the old Fairfiled Hills mental institution grounds - most of the old buildings have been demolished or renovated. Quick useless fact #2: Fairfield Hills was used to shoot the movie "Sleepers", which starred Robert DeNiro, Brad Pitt and Kevin Bacon. Quick useless fact #3: Some people say Fairfield Hills is haunted.
thanks for this. very useful.
I have an iroad ione 3800FU to install in a week or two. I probably should've got the 3300 as it can be bought with a rear camera but is lower res.
One thing I forgot to mention: the location where mine is installed MAY affect your rear view mirror dimming. It only bothers me in low light DAYTIME conditions, though; because the sensor is blocked, on really overcast days, the mirror thinks it's night and dims itself. Makes it hard to see... But it is easily fixed with a click of the OFF button.
Mirror turns itself on every time you start the car, so it's a pretty easy and good workaround for me. Good luck... And post your videos :)
Looking for a rear camera and don't want to drop $300 bucks on another Itronics.
What about this at half the price of the Itronics?
http://www.ebay.com/itm/330876105855?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Kind of a 'Blackvue-ish' style but with lots of venting to (hopefully) avoid the overheating issues that have plagued the Blackvue design.
GPS optional, which you don't need anyway. Some of the video on Youtube looks as good if not better than the Itronics. Must be the Sony CMOS sensor.
Have you videoed any meteors lately, Ruissimo?
I guess the 250HD is out now.... wish I could find some 100HD's for under $150. I'd buy an extra for the rear window in a heartbeat.
