stuofsci02
- Jan 2, 2012
Let's see if I can clarify this. The ONLY torque that matters in accelerating a car is the torque at the REAR WHEELS. That is determined by gearing as well as the engine.
How fast the car accelerates is determined by how fast the wheels can be spun at that torque-------------------------WHICH EQUALS HP!!!
Again, a gas turbine, that only generates 100 ft-lbs of torque, will accelerate a car rather rapidly because it is also turning 30,000 rpm and generating 570 hp.
OR:
Accelerating a car requires work to be done as a car at 50 mph has a lot more energy than a car at 25 mph. Work per unit time, by definition, is hp. You can accelerate a car from 25 to 50 mph with a low hp engine---------if you aren't in a hurry. The quicker you get from 25 mph to 50 mph, the more hp you will need in that engine.
+1... This is exactly right..
HP is a measurement of power (obviously). Power is the amount of work that can be done in a unit of time.
To take your Prius example a step further, if at 1200 rpm it makes 67 HP. Then at that exact point it would accelerate the same as a gas engine that makes 100 lb-ft TQ at 3,518 rpm.
A 2008 F1 Engine only produces between 200 and 240 lb-ft across the RPM range but produces over 750 HP because you can rev it to 19,000 RPM. This would provide faster acceleration than a 500 lb-ft motor that makes 500 hp, providing you are operating both motors in their peak HP range (which should be a given).
This is all very basic engineering...
