mcginnpm
- Jul 22, 2009
- Location
- The Low Country of South Carolina
- Genesis Model Year
- 2017
- Genesis G80
Re: Fuel Tank Air Filter / Fuel Filter
I finally got around to replacing my fuel tank AIR filter today. It's a bit of a PITA, but not too bad if you don't mind hanging over the trunk sill while you're working. If you want to be more comfortable, you can pull the rear seat back out.
Step 1 - Remove the carpet from the trunk. You'll see a styrofoam pad. Remove the two plastic nuts (they were just hand tight on my car) and remove the pad (see photo 1)
Step 2 - You'll see a retangular access panel. Remove the ten 10mm bolts and remove the panel (see photo 2)
Step 3 - Disconnect the electrical connection from the solonoid valve, disconnect the hose from the charcoal canister, and remove the 10mm retaining bolt (see photo 3)
Step 4 - Disconnect the hose from the fuel tank air filter. Note: it's possible, but not easy, to disconnect it from inside the trunk. Its easier if you do it from under the car. Look for the hose and the filter just above the differential (see photo 4). You could do this before Step 3 above, but it was Step 4 for me when I realized what a pain it was to try and disconnect the hose while I was in the trunk.
Step 5 - Remove the fuel tank air filter. Note: you'll need to wriggle it around a bit to get the valve and hose clear (photo 5 shows how things look with the filter out. You can see the hose that was disconnected from under the car. It doesn't pull up into the trunk area very far. If you've got small hands, you can probably work it from inside the trunk to get it disconnected. Otherwise, just jack up the car, put it on stands, and crawl underneath. It's a LOT easier.)
Step 6 - Remove the two 10mm bolts that mount the solonoid valve and hose to the fuel tank air filter (see photo 6)
Step 7 - Remove the rubber grommet and metal sleeve from the fuel tank air filter (see photo 7)
Installation is the reverse of the above steps.
I don't know why they call for a fuel tank air filter change at 30K? Photo 8 shows the old and new filters side-by-side. I'll let you guess which one is which. The old filter looked brand spanking new to me. Overall it took about an hour to do the job. Now that I know what I'm doing, I could probably do it in 25-30 minutes.
Hope this helps folks
Hi everyone...
I pulled the recommended maintenance schedule from Hyundai USAs website.
It says at 30K to have change the fuel tank air filter and at 37500 to change the fuel filter. For the V6...
Has anyone changed these themselves? I don't think I have seen much discussion anyone changing these..
Bob Hall
