Most common location for UNAVI Control Box?
shopkins82
I just bought a '12 Genesis 3.8 Sedan. It came with the UNAVI X2 navigation system installed (not sure if by the original dealership, first owner, or dealership I purchased from). After looking the car over in detail I can't seem to find the location of the Control Box containing the SD card. Could others who have UNAVI, either self-installed or dealer-installed, let me know where the Control Box is most commonly installed?
Thanks in advance!
Thanks in advance!
Can anyone help? Haven't received any responses in the UNAVI thread either...
Yes, did you? None of those FAQ questions address where the control box is normally located...
It says to contact their Technical Support folks before messing with the SD card, regardless of where it is.
And directions for uploading custom background images to the SD card are right there in the owner's manual...
I have not been able find an answer as to the actual location of the UNAVI control box. If it is in the glove box as stated by UNAVI manual as the most common location, it is well hidden. I am looking for an answer too.
byron_m
Since we did not do the installation it would be best to remove (or have car stereo shop remove) the main screen and trace the wire harness to the control box. The harness is not that long so its not like it will be in the trunk, there is a good chance that its behind the screen or tucked on the side of the dash or behind the glove box.
