Doubled613
- Mar 27, 2014
Hi guys. I know my 2011 hyundai genesis sedan has TPMS but where can i view the pressure on the screen or does it just come on when the tires are low?
Only when tires are low as far as I know. But even if it did, it is not accurate enough to substitute for you taking your own air pressure measurements. The newer digital tire pressures gauges are quite accurate, even the ones that are fairly inexepensive.Hi guys. I know my 2011 hyundai genesis sedan has TPMS but where can i view the pressure on the screen or does it just come on when the tires are low?
I don't know, but when the warning comes on, and the low tire is inflated to proper levels (and assuming there is no actual leak) then it does take driving for a few minutes for the TPMS warning light to go out.Does anyone know if the TPMS in our cars actually measures the pressure and transmits the data to the display, or simply uses an algorithm via the ABS to count tire rotations relative to one another and detect changes in tire diameter caused by deflation?
The tire pressure has to be "substantially" low in my experience before the warning light comes on.One could over-inflate (temporarily) 3 tires, leaving one tire at normal pressure, and see if that tire is flagged as "low". If it's an algorithm of rotation, it should.
