Samsung Galaxy S5
ngayle
I have a 2015 Genesis V6 Ultimate, and it refuses to download the contacts. It pairs right away, then warns that the contact download is about to start - check your phone for permission.
It then proceeds to loose the pairing and repeat the sequence until I select NO when prompted to try again. This occurs every time I start the car - help
I have an S5 and never had that issue..my guess is the phone wont allow the download to happen
have you tried restarting your phone and re=pairing it to the car?
When you get that message you need to go to your phone. It will ask if it ok to download contacts and if its ok to do it without asking.
At least that's what had to be done with my S5.
Yes, I've done it both ways "ask" and don't ask again. I've popped the battery, fctory reset phone and car - still the same thing
The fix?
With your BT turned on:
Settings > Applications Manager > Running (slide accross) > Bluetooth Share > BluetoothPbapService (you need to 'Stop' this application).
This should then allow your device to talk to your Genesis. This will need to be done each time you turn off the Bluetooth on your phone.
