Trunk Organizer
Onuriss
Mooresville, NC
For anyone looking for a great trunk organizer, I found that the Rola 59001 M.O.V.E. Rigid-Base Trunk Organizer fits perfectly in the trunk space directly behind the back seats.
It's a really nice organizer with a semi-rigid base, string handles, and has the ability to fold flat. It has a ton of reviews and still has a 5-star rating too. Check it out if you are in the market.
I purchase mine from Amazon
Did you ever consider the smaller size (Model 5900)? I worry that the model you got may be too wide. Do you use the organizer so that it is placed across the width of the trunk?
The model I purchased does fit across the width of the trunk, even when pushed all the back against the back of the rear seats.
It's nice to have that. I actually purchased one from HyundaiAccessoryStore and it has original Hyundai sign on it. Also have the net as well. And the hook on the top of the trunk is very good option to hang grocery bags :)
PHOTO REMOVED for readability
I have almost exactly this trunk organizer, which I bought specifically for the 2015 Genesis due to the lame-ness of the floor mounted cargo net. It's this exact design and manufacturer, but 25 inches wide instead of 38. The width is perfect for me, as you can slide ir right up against the rear seats, and still have about 8 inches to the side to put something else in if you want. It will stay wherever you put it -- ie, it will NOT move around in the trunk.
[ame="http://www.amazon.com/gp/product/B000E7YP7I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1"]Amazon.com: Rola 59000 M.O.V.E. Rigid-Base Interior Organizer (25" x 15"): Automotive[/ame]
The photos below show exactly how much room you have to work with both horizontally and vertically. It is an extremely well made product.
Is there any strips on the organizer? Mine has strips that you can attach to those clips on the trunk floor,it's stays without moving at all.
It has a clip on each side which I presume you could attach to the clips on the trunk floor, but not strips that wold reach out to the trunk floor clips. Honestly, if you have a rubber floor mat in your trunk, this thing shouldn't need to be tied down. It's very stable.
EDIT: It doesn't have a "clip" on each side, it has a mounting ring that you could attach a clip to (or Bungie cord, etc). Also, it's only at each end, not on all 4 sides. I didn't want to be misleading in my reply.
You bought the 59001 (38 in) and it fits right against the back seats of the 2015 Genesis? I just want to make sure it will fit.
According to my tape measure, the width from side to side at the very rear of the trunk is 36 inches. That's the reason I didn't purchase the 38 inch version of this object. I don't see how it could fit right up against the back seat, but maybe it isn't "exactly" 38 inches wide, and maybe there's enough flexibility to "stuff" it in there. Maybe Onuriss, could post a photo in his trunk?
Yep. I got the same measurement so Im hoping that snug fit will keep the organizer and my groceries in place while I take the corners at 70 mph... :)
The larger version of this trunk organizer does fit perfectly when pushed up against the back of the back seats. I attached a picture of it inside my trunk.
Thanks for posting that. Looks like you've got the backside compressed in to make up for that 2 inches of overlap, but you got it in there. Good job in maximizing that space.
ok.. I ordered mine earlier today. Should be here on Tuesday. Gotta love Amazon !!
Thanks for the pic. I am going to order one now.
Hope you all like it as much as I do. The two best features of this thing are the ability to fold it down to make it flat if I have larger items to place in the trunk, and the semi-rigid base that makes it super easy to lift out of the trunk.
It looks good,quite bigger than I got from Hyundai Accessory Store. But I can't complain about mine too, it fits perfectly and I am able to tie it down. And I love those grocery bag hooks,they are great:)ImageUploadedByTapatalk1413855013.035008.webpImageUploadedByTapatalk1413855034.468448.webpImageUploadedByTapatalk1413855063.838911.webp
Ahh,ok ,thanks for clearing that up, I was thinking it could be for umbrella,I even tried to put one in there :) but it was too thick,may be thiner would fit :)
