regular gas
marik77
hi guys,
can i use regular gas instead of premium on my genesis cope 2.0 turbo automat
Hello marik77....i have a 3.8 and will more than likely run Premium, as both of these engines are hi performance. Having the turbo 4 cylinder and running regular you "could" run into some long term engine damage.
Just my 2 cents...
I have the 3.8 in both a sedan and the coupe. I use regular for both cars and it works fine. I'm not sure about the turbo in the coupe. If the manual says it needs premium, then do what the owners manual says. If the owners manual does not require it, then it is your choice.
There is a lot of discussion on other treads on premium versus regular gas. I vote for the cheapest as they both have the same engine cleaner additives for longer lasting engines.
My father was a petroleum engineer, brother was a chemical engineer, and my father in law worked in the "Knock Lab" at a major refinery all his life. They all say the same thing. If the engine does not knock on the regular fuel, then it is fine.
That's true as far as it goes, but most modern engines that have been designed to use premium optionally can get more power with premium, but retard timing if knocking is detected when using regular, therefore getting optimal, but (potentially reduced) performance with either blend.
thank you guys for your advice !
