front passenger seat belt clip too low
gobluefan
Central Ohio
My wife is constantly complaining that the passenger side seat belt clip (the part that you insert the seat belt buckle into) is too low. She is worried that wedging her hand and fingers down into the narrow space between the transmission tunnel and the seat might damage her wedding ring. I checked and the driver side clip is mounted much higher than the passenger side clip.
Does anyone know if the passenger clip can be mounted higher?
Go to this site and buy a rigid extender:
https://www.seatbeltextenderpros.com/hyundai-genesis-seat-belt-extender/
They come in black and beige.
You could try also Amazon.com if they have what you are looking for.
It is from the same company Seat Belt Extender Pros.
You might pay a bit less with Amazon.
For me just bought one from Amazon.ca and save $6.00 with same free shipping.
Double entry deleted
Ditto. My wife complains about that all the time as well. Her rings have scratched the sides of the console trying to connect it.
Use left hand instead of right to latch and unlatch belt. Simple enough. Put latch in left hand while pulling top shoulder section with right hand. I do it all the time.
Obviously you haven't seen my wife. She's got rings on just about every finger on both hands :D
The younger generations have moved those rings off their fingers and onto noses, ears, lips, eyebrows and genitals. They may look freakish, but at least they don't scratch their car consoles.
Thank you all for your helpful suggestions. I think I will buy a seat belt extender.
I looked at Amazon, and they come in all sizes and lengths. What size will fit our 2015 Hyundai Genesis?
For example, from the Amazon description:
Metal tongue dimensions of this item - tongue width: 21.5mm, hole width: 11.5mm, hole length: 20mm, measurement of metal bar between top of hole and tip of metal tongue: 6mm. Do not purchase this item, unless your seat belt metal tongue's dimensions where you need the extender matches all these dimensions.
Make sure you get the rigid extender. I bought a 7" extender which will pop out above the heaviest winter coat. I bought directly from Seatbelt Pros, so selection of the correct extender was not an issue.
Ignoring the four holes in MY ears ... I totes got a major LOL from this ...
Regardless of which extender you choose (I found a pair available in three different color choices on Amazon for $40.00 that I'm happy with) keep in mind that there is a driver and passenger side to these extenders. You want the red release buttons on the extenders to be in the same location as the factory buckles - release buttons near the console).
