JBoogie
I know that there are 2 spkrs in each of the front doors.. Does anyone know what size each of those spkrs are?
Thanks.
Thanks.
I would not recommend replacing them with something besides the OEM ones, because the head unit frequency response is custom equalized to the characteristics/limitations of the exact OEM speakers. Also, they are not standard impedances, so the volume and amplifier load will be different if you replace them with after-market ones.I know that there are 2 spkrs in each of the front doors.. Does anyone know what size each of those spkrs are?
Thanks.
There is thread on this forum where a professional installer put in a very high-end competition system (with support from multiple suppliers) that looked like it would cost about $25K retail. He may have listed the old specs, or at least the replacement speakers he used.Just wondering what size they are without taking my door apart.
If i do decide to change any speakers i will do the whole system. This aint my first rodeo Hoss.![]()
Long ago, it was easier to create a reasonable car amp using lower resistance speakers. So, in a nut, that is why cars are 4 ohm and homes kind of stuck with 8 ohm. I have no clue why homes standardized on 8 ohm. Someone else will google that, I am sure.I have a question - As I understand it, the aftermarket systems are standard on 4 ohms. The home units seem to be 8 ohms.
Why do the factory speakers/amps use different than 4ohms? What is the advantage/disadvantage? Why different than the 4 ohms that aftermarket units use?
Except that the precise speaker sizes are probably not in metric sizes to the nearest cm. They are probably in inches.
+1The info is from Lexicon. Typically Hi-Fi manufacturers use the metric system when building speakers.
