The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I just completed a 6 hr round trip from DC to DE and I was easily getting 27mpg on the highway. How is EPA only rating it as 23? Is mine some kind of a freak?![]()
2008?
Until they flashed the CPU against my expressed banning of such procedure (it had original flash from production), I would get 30+ on highway if kept under 75-78 (depending on winds) where it the ECO light stayed on. Premium used with Local CO-OP based ethanol free 91 or Shell 93. I had a high average in rural 4 lane of almost 35MPG flat, no wind, and under 64 or under MPH.
Once the flash happened, best I have done is 28. Typical about your mileage of 27, slightly less in winter (with 19" R-Spec wheels and Blizzaks) . I have 18" Michelin on 5.0 non R-Spec. I am cranked about the morons doing the flash update. Whatever Hyundai did for the CPU flash update, I have soot on the bumper. Also, in town dropped from about 23-25 in suburban driving to 19-21.
I was very pleased with mileage. I keep the tires a few lbs over spec. Better handling, and seems to have less rolling resistance. Also, check the alignment, many came off the boats goofed up when they were tied down. Mine was off out of the factory. Also, Brian was my witness.![]()
One other item. The other picture is of a procedure I do every 10k miles. Knocks off the deposits on the intake valves (PCV blow by, since DI does not wash intake valves with detergent gas)... That also helps. Plus keeps one from eventually having to walnut clean the intake valves.
View attachment 5184View attachment 5185View attachment 5186
If you have not had your CPU flashed, make sure they do not.View attachment 5183
What is a "CPU flash" and why would this be done? I'm envious of your gas mileage. I drive the 3.8 AWD and I'm struggling to get 22MPH and I use Shell 100% gas. Thanks for your response.
I am running 2012. Not 2015. Which is at least 550lbs heavier (or more). And no AWD. The 5.0.. I would like to know if 3.8 AWD folks can get a tank full in high 20s or more..
Recently returned from a 4k mile trip from NY to FL, TN, OH and back home in my V6 AWD. On the way down, still getting broken in, I observed mpg numbers in the low 26's. On the way home through PA, my best observed was 28.7. Also, it seemed that running in high 70's mph gave better mileage than running low 70's.
