Cell Phone, Keys, Wallet Etc.... In the Equus
ASHDUMP
OK, so since owning my Equus for a few days I'm having a real dilemma with a few things...
1. Where do I put my wallet? My Genesis had a nice slot under the CD player. It fit perfectly. The Equus has an area below the CD player but for some reason it doesn't fit that well in there.
2. Where do the keys go? My Genesis had a dedicated slot for the FOB. I think the area under the CD player will be used for the keys...
3. Where can the cell phone be (in plain view) so I don't leave the car without it? I kept my cell phone next to my wallet in the Genesis... the slot fit both.
Sounds petty I guess but would like to know what other do. I can't drive with things in my pockets... even the keys.
Can't figure out where to put things in the new Equus. Them is some problems to have right there. :D
Cell phone in genesis and Equus goes in the pocket on the door panel where you would grab to close the door with your hand. Works good there.
Genesis in 2013 dropped the key slot you are referring to and the storage under the CD player became a drawer that opens and closes.
The slot for fob in older Genesis models was for when the battery in the fob was too weak to otherwise work. It was not supposed to be used in normal circumstances.
I carry my wallet and fob in my pockets at all times. If I didn't, I am sure that I would end up in a heap of trouble.
Thanks for the replies....
I didn't know the key FOB holder in my older Genesis wasn't supposed to be used daily... I did use it all the time because it was a perfect spot out of the way.
Trash is my next challenge... Used to keep a plastic bad wrapped around the shift knob. Can't do that now with the Equus.
I can't seem to find any good trash bins online that would fit with the lux of the Equus. They all seem Lexus LS if you ask me.
You bring up a adjacent question that goes back and forth. What does the FOB slit really do? I have heard in here it will shut down the FOB extending battery life. That is will do as you say above. Or it does nothing but provide storage. I wonder if anyone that has the PDF shop manual can look up the diagrams to see if this is just a passive storage function, or if there is part numbers of electronics and wiring associated with it. Or if someone remembers what the owners manual says that applies. I will get to the owners manual in a day or so.
The slide out drawer idea seems good. Semi private place to put something.
Since the Equus does not have a spot, initially I like the idea in the door handle. I tuck things in that too. Except, if it is not deep enough, will cause the phone to fly out when closing the door hard enough to seal it shut.
The older fobs, both the Genesis and the Sonata had rechargeable batteries. The docking station insided the console was a charging unit. My dealer told me to just put the fob in the dock during a long road trip and it would keep it charged. I had my 2011 until last year when I traded for my 15 and I had one fob go dead right at the end because I never charged it.
Thanks. I have heard this too.. But then others were firm on debunking this theory. And I did not find this feature in the 2012 manual. This would mean they have a rechargeable battery in the Fob.. Anyone confirm this?
If you can't keep your wallet in your pocket, either you or your wallet need to shed some bulk. Same with keys and phone. The iPhone 6 is my phone size limit. Another option is a man-purse. Then you could carry a Twinkie along too.
I have a 2009 Genesis sedan, and I am pretty sure the battery is not rechargeable. I have replaced the battery on both my FOB's simply as a precaution, since I got 2 batteries for about $4.50 at Walmart. The 2032 battery originally included looks just like every other 2032 alkaline battery I have seen (my home theatre remote controls use that same battery). I also replace my garage door batteries before they completely run out, just as a precaution. This is not rocket science.
At some point (not sure when, maybe 2012/2013) they eliminated the slot, and you just place the FOB near the start button if the battery is too low. I think the slot just gets the FOB close enough that it works with a very weak battery, or maybe without any battery. But a FOB battery can easily last 3-4 years even if the battery is not replaced or recharged, so even if the slot prolongs battery life (I personally am skeptical about that) it is not worth taking the FOB out of my pocket to put in the slot, and then have to remember to take it with me when I exit the car.
In any case, replacing the battery on the FOB is very simple, unless you are afraid of screwdrivers (needed to pry it open).
Just to come full circle on the FOB question. I'm almost 100% certain that the slot in my 2009 was strickly for turning the car on if your battery was completely dead. If you were to take out the battery in the FOB, then insert the FOB into the slot (fully until you hear a click and your steering/seet move into your set potion) the car will start.
IT was only meant for a means of starting your car when the battery died in the FOB. There is no way it can actually charge the battery becuase there are no metal contacts on the outside of the FOB. Just plastic all the way around..... And I know it doesn't have Qi (wireless) charging.
Anyway... another gripe I have with the Equus and its layout is the phone charging station...THERE ISN'T ANY! I'm shocked that there isn't a passthrough in the center console for the phoone charger..... blows my mind.
I agree on this point. My business partner has a 2014 Equus Ultimate. I was just riding with him this week and we were both discussing how dumb the charging situation is in the car. No thinking at all on that!
Even on the Genesis, I am surprised there isn't at least a 12V socket in the back seat area. Makes no sense to me. Even a Ford Focus has that!
The Equus has two 12v plugs in the back center console. But there is no way for wires to come thru it. So whatever you plug in will need to stay in the console... which kind of stinks.
My wife's new Kia Sorento SX has a 12v plug along with a 120v standard USA plug in the back which is cool.
Its really hard to find flaws with the Equus but I keep managing to find certain things that just dont make sense.
Here's another one.... Maybe the same in the Genesis?
The two center console cup holders are different sizes and the smaller size doesn't really fit any kind of "to-go" cup nor fast food cup. IF that is the case what can it be used for?
I thought maybe I would stick my phone in that cup holder (LG G2) but its too wide.
Just wanted to get that out there! First world problems.....
I'm sure this has to do with Korean car. In Korea they have soda cans which are smaller than standard North America cans. They sized the cup holder for that smaller Korean soda can. You could probably google the image of a Korean soda can.
Exactly. Many cars nowadays have a 120V plug. Seems Hyundai should have included this in both the Genesis and Equus.
I'm contemplating drilling a hole in the side of the center arm rest (Passenger side) so I can pass my cell phone charger thru it. I could get a finished grommet so it doesn't look like a hack job.
But, not sure if I have the balls yet to do it. I'm pretty sure there are no air ducts or wires running along the side of the center arm rest.....?
Well after reading the full operation manual on my iPad I found out that they show the cell phone charger cable being snaked thru the front corners of the front arm rest. While it is not ideal it does work. The thinner the cable the better it will work. I have three cables and one of them is too thick so I swapped it out for the thinnest one I had.
So no drilling of any holes just yet....
At least on mine, there are small indentations on the corners of the lid, just for that purpose. You have to lift the lid and look at the bottom of it to see this.
You could never charge key fob battery in prior Genesis models.
But the issues still remain. Where do you place the phone after its connected? In my 2010 Genesis I placed it in the ashtray which doesn't exist in 2015 Equus..
As to other issues;
cup holders too small and there should be four including 1 in each front door
center console buttons, especially seat heat/cool not placed properly
2010 Genesis GPS easier to use than one in my Equus
for those that use a battery tender no hook-up under the hood
But otherwise no comparison Equus rides substantially smoother (even when compared to new Genesis).
