Set screws - universal??
NJTom
Central PA
I have a 2009 V6.
When changing out the brake rotors I would assume to also replace with new set screws. New screws were not included with my EBC rotors so I have to get new ones. Can I go to the local auto parts store or to the dealership or are they a universal part? Any help would be appreciated.
Thanks.
I have a 2009 V6.
Thanks.
Set screws are primarily only needed during initial vehicle assembly, as a rotor falling off and striking a worker is typically frowned upon.
They are reusable and I do not tighten mine down, makes it much easier to remove the next time, as the wheel and lugs will perform the same function.
Since they're only "convenience screws", I would use anything available that fits.
I'm assuming you trashed the old ones getting them out.
Be sure to coat the new ones in lithium grease. Then they don't seize and you can get them out easily enough when you put on your next set of rotors. Don't worry - the rim holds them on - they aren't gonna vibrate out. :)
