tmf2004
this is my first car with the pano roof. Any special care instructions? thanks
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
First... welcome to the forum.
Now - the post above is a comment that refers to the fact that some users have issues with rattles. Many, and probably most do not.
Pano roofs are more prone to noise issues due to their larger size.
So far, my Genesis is quiet. I had a rattle in my '13 Azera, but that was easily fixed with a felt shim. (not visible.. and the fix worked)
Some users have had continuing issues. If you search, you will see some of these accounts. Hyundai seems to know about the issues, and recently there have been some posts from users who had the entire roof replaced. These reports are fairly recent, so it may be too early to know if the fix is permanent, though that has seemed to quiet the issue for now from those reports.
Remember that many posts in a forum like this will refer to negative issues. That does not necessarily mean that you are likely to have the problem, but the forum will arm you with some info for what to expect if you do have any problems.
My 2015 hasn't had any issues thus far.
Only thing I can think of is to not open it when the roof is dirty. Not sure if if opening and closing the panel drags road film and dirt into the mechanism or not.
Knock on wood, mine is quiet. Creaks a tiny bit when the body is stressed.
I had a rattle that was only detectable at HWY speeds. Took it to dealer and they added felt padding to the cowling (area just below where the wipers reside) and the rattle was cured.
Was told it was a known issue and the resolution was more padding. The vibration presented itself as emitting from the dash area and I could not identify where it emminated from until the service tech found and cured the problem.
Was that related to the Pano roof? (This thread's topic)
