Information from the manual - Hope this helps:
Mechanical key
If the Smart Key does not operate normally, you can lock or unlock the door by using the mechanical key.
Press and hold the release button (1) and remove the mechanical key (2).
Insert the mechanical key into the key hole on the door.
To reinstall the mechanical key, put the key into the hole and push it until a click sound is heard.
Smart key precautions:
The smart key will not work if any of the following occur:
• The smart key is close to a radio transmitter such as a radio station or an airport which can interfere with normal operation of the transmitter.
• The smart key is near a mobile two way radio system or a cellular phone.
• Another vehicle’s smart key is being operated close to your vehicle.
When the smart key does not work correctly, open and close the door with the mechanical key.
If you have a problem with the smart key, contact an authorized HYUNDAI dealer.
If the smart key is in close proximity to your mobile phone, the signal could be blocked by your mobile phones normal operational signals.
This is especially important when the phone is active such as making and receiving calls, text messaging, and/or sending/receiving emails.
Avoid placing the smart key and your mobile phone in the same pants or jacket pocket and always try to maintain an adequate distance between the two devices.
Immobilizer System:
The immobilizer system protects your vehicle from theft. If an improperly coded key (or other device) is used, the engine’s fuel system is disabled.
When the Engine Start/Stop button is in the ON position, the immobilizer system indicator should come on briefly,then go off. If the indicator starts to
blink, the system does not recognize the coding of the Smart Key.
Press the Engine Start/Stop button to the OFF position, then press the Engine Start/Stop button to the ON position again.
The system may not recognize your Smart Key’s coding if another immobilizer key or other metal object (i.e.,key chain) is near the Smart Key.
The engine may not start because the metal may interrupt the transponder signal from transmitting normally.
If the system repeatedly does not recognize the coding of the key, contact your HYUNDAI dealer.
