Several folks recently have reported that they are missing the orange and black wires at the bumper for the fog light install using the 5.0 multi-function switch with the fog light option on the switch. I was in the same boat and while I have a current install that gives me even more options I wanted to eventually have an option for a complete factory type configuration system. I did not have the orange and black wiring at the bumper for the fog lights and was unsure what I could do wrt installing the multi-function swtich and wiring it up so it would operate just like the factory OEM system including the dash indicator light.
I paid for a weeks worth of access to the manuals on the Hyundai service site and downloaded the entire ETM for both my vehicle along with the 2015 5.0 and 2016 3.8 sections concering lighting. I thought I had identified where the fog lights originated from which then go directly to that bumper connector on the driver's side. However, w/o the switch I was unsure if it would provide the power for the fog lights when installed.
I just received my switch from rpmtrade via e-bay and have confirmed with a multimeter where the fog light power originates and that it seems to work just like the OEM systems in the 5.0 and those on the 2016's. So this is good news for those not having the orange/black factory wiring at that bumper connector. The bad news is that is a little more complicated to wire things up and get them as close to factory as possible. First one needs to install the proper contacts into the spots on the connector that powers the foglights. Next one has to find an alternative to using that bumper connector on the driver's side since that is a KUM connector and as best as I can determine there are no U.S. sources for pins to add wires to that connector. I believe I have found a source (Mouser) for the missing pins in the fog light connector that is the source of the power for the fog lights. For the bumper connection I plan to use a 4 conductor AMP weather proof one and run two orange wires back to the fog light power source and two black wires to ground somewhere. This will mimic the OEM orange and black wires on the bumper connector. From there I will run separate orange and black wires to each fog light since I think you need this to allow for the tell tail light out fault function to work correctly. I already have the fog lights wired up, but the run from the bumper up the passenger side of the engine compartment and then into the cabin to my fog light relay control box. I haven't finalized ultimate wiring configuration since I would like to retain the existing reduced brightness Fog Light DRL function along with the ability to turn on my fog lights regardless of what other lights are on. The OEM system only allows the fog lights to be on with the low beams. The purpose of going to this extra work in my case is that I have to pass an annual Va state safety inspection and want my system to look 100% OEM to the Inspector and to operate as such for at least inspection purposes.
FWIT the connector that appears to supply the fog light power is the one on the IGPM co-located with the fuse block under the fuse panel located behind the driver's crash pad. The connector is the 16 pin connector at the upper right with double rows of 3 each on each side of 4 larger wires in the middle. The larger wires in the middle should be from the left to the right looking at the connector from the wire side are White, Yellow, Red, BLANK.
The fog light connector pins are the two blank locations on the bottom row to the right of the larger wires and has a single grey wire in the row in the position closest to the interior of the vehicle.
I still have some work to do mainly to confirm what I have targeted for the new pins in the connector on the IGPM are the correct ones and that has to wait for the donor pin connector currently on order from Mouser.
It' going to be a while (weeks not months), but I plan to document with pics what I did that is new from what has already been documented along with sources and part numbers of things like the correct connector pins so the fog light wires can be added to the existing connector on the IGPM.
I will be happy to answer some of the simpler question in this thread, but want to wait on the nitty gritty until I have confirmed 100% that what I'm doing will really work.
So it appears the good news is there is hope for those wanting to add a very OEM type fog light system to their 3.8 on vehicles w/o the orange/black wires in the bumper connector. The bad news is that is not a real simple plug and play, but should be something for those with moderate ability to do.
Larry
Larry
