Should I get a Genesis? Couple of Questions... :)
Hey Guys!
So I test-drove a 3.8 Genesis (in Germany) today. Was really impressed. As I am currently driving a 2013 Chrysler 300 Luxury Series this came as a bit of a surprise... ;-)
Got a couple of questions though before committing to the new car:
  • Bluetooth audio streaming worked fine with my Microsoft Lumia 950 - But when making or taking calls nothing was being transmitted tot he car. speakers remainded silent. Is this a known Problem with Windows Phones? Is there a compatibility list somewhere?
  • Could you provide me with real world MPG for highway and city?
  • The car seems to have a semi-automatic highway mode in Asia where the lane keep assist never shuts off - is there a hack to enable this?
  • Are there any known problems/issues with this car that I should be aware of, especially switching over from the chrysler 300?
  • How would you rate the navigation system compared to the garmin-based chrysler navigation?
  • Is the car FlexFuel / E85 compatible?
Thanks! :)
Regards
-DR
Hello DR,
My previous car was a Chrysler 300C with most options (except sunroof and V8/AWD), so I think I can speak to your question from a good perspective with regards to the Chrysler comparison.
[*]Bluetooth audio streaming worked fine with my Microsoft Lumia 950 - But when making or taking calls nothing was being transmitted tot he car. speakers remained silent. Is this a known Problem with Windows Phones? Is there a compatibility list somewhere?
I had problems with Bluetooth (older LG phone) in my Chrysler, which went away when I got an S6. The Hyundai seems to be fine with my phone, but sometimes I have to disable and re-enable Bluetooth on the phone for the music to stream (won't recognize the Media input otherwise). I have no experience with Windows phones, so I can't comment on that. I think generally the BT technology has matured in the past few years. The Hyundai does not support the display/reading of text messages - I thought that was standard fare now, since my Chrysler was able to do that in 2013.
[*]Could you provide me with real world MPG for highway and city?
My mpg is about 1 - 1.5 mpg worse with the Genesis V6 vs. the Chrysler V6, same route, same traffic, same gas, same driving style. I think that's a huge let down, I got around 20-21 mpg with the Chrysler, I get around 19 - 19.5 mpg with the Genesis:
attachment.php
[*]The car seems to have a semi-automatic highway mode in Asia where the lane keep assist never shuts off - is there a hack to enable this?
My lane keep assist is on all the time - it's also very wonky (especially at highway exists or whenever one of the lines on the road fades or disappears) and I wouldn't trust it to guide me properly unattended. It's a dumb system, not sure if that's different in Asia. It does work most of the time for what it was intended, but it's not reliable by any standards.
[*]Are there any known problems/issues with this car that I should be aware of, especially switching over from the chrysler 300?
Sunroof seems to be a problem for many. The "Ultimate" trim doesn't get Apple Car Play / Android Auto (not an issue with a windows phone I guess), there are some annoyances (lighting from factory is set very low, Xenon's don't have curve lighting function, no way to activate the seat cooler/heater with remote start, etc.), but overall the car seems relatively trouble free, as was my Chrysler.
[*]How would you rate the navigation system compared to the garmin-based chrysler navigation?
Personally, I think the Navigation System (at least on my 2015 Ultimate) is garbage, especially compared to the 300's Garmin system. Routing is bad, sometimes totally wrong, no 3D map (unless you pay $200+ for the map update), bad Voice recognition - I'm not impressed and liked the UConnect system for it's abilities and ease of use. You get used to the Hyundai system, but it's not as intuitive and certainly the navigation functionality is much worse.
[*]Is the car FlexFuel / E85 compatible?
This is from the manual:
Gasoline containing alcohol and methanol
Gasohol, a mixture of gasoline and ethanol (also known as grain alcohol), and gasoline or gasohol containing methanol (also known as wood alcohol) are being marketed along with or instead of leaded or
unleaded gasoline.
Do not use gasohol containing more than 10% ethanol, and do not use gasoline or gasohol containing any methanol. Either of these fuels may cause drivability problems and damage to the fuel system.
Discontinue using gasohol of any kind if drivability problems occur. Vehicle damage or drivability problems may not be covered by the manufacturer’s warranty if they result from the use of:
1. Gasohol containing more than 10% ethanol.
2. Gasoline or gasohol containing methanol.
3. Leaded fuel or leaded gasohol.
"E85" fuel is an alternative fuel comprised of 85 percent ethanol and 15
percent gasoline, and is manufactured exclusively for use in Flexible Fuel Vehicles. “E85” is not compatible with your vehicle. Use of “E85” may result in poor engine performance and damage to your vehicle's engine and fuel system. HYUNDAI recommends that customers do not use fuel with an ethanol content exceeding 10 percent.
CAUTION
Your New Vehicle Limited Warranty does not cover damage to the fuel system or any performance problems caused by the use of “E85” fuel.
I think that's a clear message, no E85. My Chrysler was E85 capable, but I would never willingly get E85 vs other gas, it's not worth it from a financial, environmental or fuel economy perspective.
Hallo DREffects,
nachdem ich jetzt noch ein paar weitere Nachrichten von Dir gelesen habe (und gelernt habe das Du in Deutschland wohnst) hier noch ein paar weitere Anmerkungen von mir:
soweit ich weiß kann man in Europa keinen Genesis ohne Schiebedach bekommen, und das am meisten beschriebene Problem hier ist das Problem mit dem Klappern des Schiebedachs (geht bei meinem Wagen, ist auf schlechten Straßen aber wahrnehmbar). Ich weiß nicht wie Kulant Hyundai in Deutschland ist, hier in den USA sind die Händler generell etwas entgegenkommender als in Europa (zumindest als ich noch dort wohnte), und selbst hier versuchen die Händler die Leute wegzuschicken, wenn sie mit Schiebedachproblemen ankommen.
der Durchschnittsverbrauch bei mir liegt bei 12,2 L/100 km, mein V6 Chrysler brauchte 11,2 L/100 km – Stadtfahrten und schnelle Autobahnstrecken mit dem Genesis gehen locker über 15 L/100 km. In Deutschland gibt es den Wagen meines Wissens nur mit Allradantrieb, und das System von Hyundai ist dafür bekannt erheblich mehr zu verbrauchen als Systeme anderer Hersteller – ich würde mit 2-3 Litern / 100 km mehr rechnen. Je nachdem wieviel man fährt kommen da heftige Summen fürs Benzin zusammen … Hyundai gibt einen Durschnittsverbrauch von 11,6 L/100 km an – ich denke das ist bergab mit Rückenwind gemessen …
Ich denke einen Genesis wird man in Deutschland nur sehr schwer wieder los. Leasing ist denkbar, aber wer kauft einen gebrauchten Hyundai Genesis? Allein der Verbrauch wird die meisten abschrecken, und Hyundai ist in Deutschland immer noch mit „billig“ assoziiert, das fährt man eher nicht als Statussymbol (wie eine gebrauchten A6, E-Klasse oder 5-er BMW) denke ich … Gebraucht sicher ein Schnäppchen, als Leasing evtl. vertretbar, aber ich würde dieses Auto in Deutschland nie neu kaufen, der Wertverlust wird astronomisch ein.
Der Wagen ist groß – in Parkhäusern in Deutschland ein Albtraum – aber wird ja immerhin mit Rundumkamera geliefert (gibt es in den USA nicht).
Da der Wagen in Deutschland kaum verkauft wird, wird man nur schwer eine gute Werkstaff finden die Erfahrung mit dem Auto hat. Ich habe beim KBA keine Zulassungszahlen für Hyundai Genesis finden können, die laufen unter „sonstige“ – keiner meine Freunde und Kollegen aus Deutschland hat bisher einen auf deutschen Straßen gesehen, alle fragen immer erstaunt was ich da wohl fahre, wenn sie mich hier besuchen kommen.
Mir gehen viele Kleinigkeiten dieses Autos auf die Nerven. Auf dem Papier sieht alles gut aus, alle wichtigen (und einige weniger wichtigen) Häkchen sind auf dem Papier vorhanden, aber im täglichen Gebrauch zeigt sich für mich das nicht alles zu Ende gedacht wurde. Kleinigkeiten, die mich am Ende aber nerven. Ich habe in der Vergangenheit einige Audi und VW Produkte geleast, und die schienen mir generell besser durchdacht zu sein.
Der Genesis ist mit Sicherheit kein schlechtes Auto, aber in Deutschland würde ich dieses Auto im Traum nicht fahren (den Chrysler 300 als Diesel hingegen schon). Wertverlust, Verbrauch und Unterstützung durch den Händler würden mich bedenklich stimmen. Wenn diese nicht so ins Gewicht fallen kann man das Auto aber mit Sicherheit genießen … ich denke die meisten Genesis in Deutschland sind an Hyundai-Führungpersonal oder an den Geschäftsführer der Händler gegangen, ich kann mir nicht vorstellen das viele Privatpersonen so ein Auto kaufen würden.
Ich beantworte gerne weitere Fragen, ich kann mich an Deinen Usernamen im Chrysler-Forum erinnern …
Austin TX, thank you for your in-depth response!
I am kinda dissappointed with your MPGs as well. By German standards the car is listed with:
City 14MPG
Highway 26MPG
Combined 20.5 MPG
Interestingly enough the combined value gets close to your actual MPG. Usually the German system kind of misses by 2-4 MPG.
I finished my test drive with 22MPG, driving 40% highway, 30% overland and 30%city.
Hm is that a seperate option? I do not see that on the German website anywhere. Infact the only thing they list is that you can play MP3s from a CD. Besides BT Streaming - is there an SD-Card slot or USB port for a portable HDD?
The car's only available with "all options" (according to the dealership) here (I guess that means the Ultimate Package) and they're calling a hefty 73.350 USD. I never would have guessed that there's no curve lighting function. Especially when they're trying to compete against Audi, BMW or Mercedes.
I think I will have to schedule another test drive at night but I guess that's not possible atm since the dealership closes at 5pm.
Very intersting how you guys have different opinions about the navigation system. :-) The Chrysler uConnect got criticized ALOT from friends and family here since it looks kinda odd compared to the mundane german design that the folks over here are used to. I myself found it to be very easy to use, yet missing a ton of functions. The POI search while travelling was a absolute bummer.
The dealership claimed that the 5 year warranty would cover one free navigation update a year. I was able to switch to a pseudo-3D-view of the map during my test drive. didn't see any 3d buildings though, but I was travelling in a rural area.
What really bugs me is that those online services like fuel prices etc. do not seem to be available in europe:
https://youtu.be/Wb6yElSlcUw?t=2m5s
Oha, Deutsche Antwort im US-Forum - wohnst Du in den USA oder BRD? :D
Leider sehr richtig :(
Ich komme mit dem 300C ganz gut zurecht, der Genesis ist ja etwas kompakter. Das passt schon :)
Puh sehr schade. Könntest du hier ins Detail gehen?
Für mich sind hierzulande Audi und BMW preislich absolut uninteressant. In Vergleichbarer Konfiguration werden hier um die 80.000 Euro aufgerufen. Das Händlerangebot zum Genesis liegt um die 58.000€, der 300C war in Vollausstattung für 30.000€ zu haben.
Bin mittlerweile Opel Insignia (zu eng), Renault Talisman (extrem laut) und Skoda Superb (ganz ok) probegefahren. Der Superb wäre der Einzige, der bislang noch in Frage kommt. Dieser ist im Innenraum allerdings Deutsch langweilig und hat zudem noch hochglänzende Dekorelemente die sich nicht ändern lassen. Preislich liegt er mit dem Genesis gleichauf wobei das ACC im Superb sehr schlecht funktioniert hat.
Ich hoffe, ich habe einen guten Eindruck hinterlassen :D
Glaub wir sollten aber wieder auf Englisch wechseln damit die Anderen auch etwas davon haben ;-)
Gesundheit! :D
As usual, many of the comments are gadget oriented.
There is actually a real car lurking in there somewhere.
V8 - lots of very smooth power
brakes - excellent
handling - excellent
mileage - great for a big V8
Quality control - best you can get
Fit & Finish - same here, best you can get
And they discount these babies!
Guten Morgen nach Deutschland,
(OK, from here on out I’ll switch back to English, as you suggested – I didn’t want to exclude anyone from my posts, I was just excited to find someone from Germany on here). I am German, but I currently live and work in Austin, TX (home of US formula 1, home of good BBQ, live music capital of the world, home of silicon hills and home of an additional 150+ people who move here every freaking day. Stay away, we’re full ;-)
I’ll go through your comments first, then add a few more thoughts.
On the trip computer: The mpg display on my car is about 2-3 mpg optimistic, the Chrysler was almost the same in this regard, about 2 mpg optimistic. The numbers I posted are actual calculated numbers, based on all my fill-ups and actual mileage driven. My trip computer display showed about 22 mpg for the last tank, actual mileage was around 19 mpg. The 22 mpg you saw was probably a real 19 mpg, maybe slightly better.
The Android Auto / Apple Car Play was an update that Hyundai provided to all owners of the current generation Genesis, with the exception of the “Ultimate” (i.e. top of the line) package. The non-“Ultimate” models use a different (smaller) display/navigation system – the “Ultimate” trim is based on different technology. The German model seems to mostly be the “Ultimate” trip with some additions (such as the surround view camera, the rear multimedia and seat controls in the center console, soft-close doors, LED read fog light, etc.) – thus they don’t mention Android Auto / Apple Car Play. There is a USB port in the center console that in the US version can be used to play music from a USB drive, or connect to your phone. There is also an AUX (3.5 mm) port to connect music players, and two cigarette lighter charging ports in the front console. The German version seems to have two rear USB charging ports (I doubt they work as stereo system inputs), the US version has no rear charging ports at all, neither USB nor cigarette lighter style – that seems like a stupid omission since every 8-year-old kid I know has a cell phone these days and they all want to charge their phones or tablets everywhere … There is an SD Card slot, but that’s for the navigation system map only I think, I haven’t tried using it to play music, I doubt that would work though. The US “Ultimate” spec radio has built-in memory, so you can upload music from a USB drive (stupidly not directly from CD or DVD) to the car.
The US version doesn’t have adaptive (swiveling) headlights (something you can get on a lowly VW Golf in the US), which I never even thought to ask about when I was looking at the car – I simply assumed that was a standard feature on any luxury car now. I loved that feature on my Chrysler, and I noticed that it’s missing the first night I drove my car – I even checked if there were settings for that, but it’s a simple omission by Hyundai. I consider this a safety feature, bad marks for Hyundai there. It looks like the German version doesn’t have that feature either, at least it’s not mentioned in the “Scheinwerfer” section in the brochure. It lists “Abbiegelicht” but that probably just means it turns on the left/right fog light when you use your blinkers and turn. “Kurvenlicht” is not mentioned.
The German brochure does state free navigation updates for 5 years, so the issues with voice recognition and 3D map features will probably have been updated, although I have no idea how well the voice recognition works in German. The US version has reported been improved with the latest map update, but I refuse to pay $200 for a software update that makes a feature that was advertised on the car actually usable. I guess map quality also can’t be compared between the US and Germany, so take what you read here with a grain of salt, as it’s probably not applicable to the German car.
The Blue Link services and the SiriusXM services cost extra after a short trial, and in my opinion are not worth the price of admission. Most of these features are available on cell phones at no extra cost, with the exception of the remote start feature, which is illegal in Germany as far as I know. You pay several $100’s of subscription fees for these things, and while the SiriusXM features usually work fine, the Blue Link stuff is not reliable in my experience. The video you linked is an extra package for the SiriusXM subscription. I don’t think you can ever save enough money by finding cheaper gas on there to pay for the service fee 
You are correct that the Chrysler 300 and the Hyundai Genesis are about the same length (the Chrysler is actually slightly longer). I would have sworn the Genesis is longer, but it may be the exterior design, plus the fact that the interior of the Hyundai feels much roomier, especially in the back. They both are boat sized, which I actually like.
The things that annoy me about my Genesis are as follows (most of these – with the exceptions of the first three or four - are first world problems, but annoying nonetheless):
I had my wheels balanced twice in the last 1,000 miles (dealer and Discount Tire), and I get a major vibration in my steering wheel from 15 – 85 mph (maximum legal speed here). Very noticeable. Extremely annoying, and apparently not related to the wheel balancing - this has been reported by multiple people on this forum. It may be tire related, it may be wheel related, it may be brake related, it may be something else. It’s absolutely not acceptable for a luxury car, and sours my experience significantly. I will have this looked into the next time I take the car in for service, but they already looked at the 1,000-mile service and told me it was fixed – which it wasn’t.
When standing at idle with the A/C running, there is a very noticeable vibration (obviously not from the wheels or axles, since stationary) that shakes the whole car. It can be reduced significantly by turning off the A/C – but that’s not really an option when it’s 100F (37C) outside. Another thing I will have the dealer look at when I bring the car in for service. Not luxury car worthy either, and passengers have commented on this, so it’s rather obvious.
The door handle needs you to push a button to unlock, you can’t just pull the handle, the door will remain locked. On the 300, you pulled the door handle with the key in your pocket and it would unlock. I got used to pushing the button, but sometimes still forget and get reminded by pulling on a locked door. Weird choice, the button press should not be necessary.
Power ports in the front of the center console (the Chrysler had them inside the center console cubby) means that you have wires running across the console to charge your phone all the time. Would have been easy to add a USB/power port inside the center console to allow the cable to stay hidden in there.
Heated/cooled seats will not come on with the remote start feature (the Chrysler had a setting where you could pick that they would start when the car was remotely started). Sounds like a stupid thing until you get into a car that has been baking in 100F+ temperatures for a few hours – the cooled seats running make it so much more comfortable to get into the car. That’s luxury!
Heated/cooled seat switch badly illuminated (impossible to see in sunlight) and in the center console – the Chrysler had the status on top of the navigation screen display in the status line.
The 17 speaker Lexicon stereo is underwhelming in my opinion. Not bad, just not what I expect from the top of the line, much hyped stereo system with 17 speakers. I think the Beats system in my Chrysler was better, but I’m not an audiophile, so I can’t really tell. I was just expecting more after reading about it in Hyundai’s marketing materials – maybe they reached the level of what my ear can actually distinguish…
This one is just stupid: The A/C controls and the stereo controls are within 2 inches of each other, and the same size. Who came up with that idea? I have blindly tried to adjust the volume and changed the temperature and vice versa more times than I can remember. That was done much better in the Chrysler 300. I know there is a steering wheel control for the volume, but I instinctively go for the center control know most of the time.
This one is big for me: The car will not remember some of the settings you chose. When I get into the car, I have to turn on ECO mode (car will always default back to “normal” driving mode, won’t remember ECO or SPORT mode between stops). Why? The car will not remember that I turned on the “Auto Hold” function, which engages the hand brake while you are stopped at a light or stop sign while in gear. That’s actually dangerous, because sometime I rely on these to work (I forgot to reactivate when getting into the car), and the car starts to crawl forward. Why isn’t this permanent until I change the setting back? The ACC setting also isn’t remembered. Why won’t the car remember that I want the cruise control on? I use that all the time, and have to reengage it every time I get into the car.
This one is just dangerous: The headlights are aimed extremely low, so they cut off very close in front of the car. On dark roads at speed I think you can travel further in two seconds than you can see, so there’s no time to react. Other have reported on this on this forum as well, and it apparently can be adjusted. Dealers claim it’s OK, based on manufacturers specifications, and I am not going to fiddle with the lights and start blinding people. This should be done right from the factory – I didn’t buy a project car that I want to fiddle with. The automatic high-beam feature helps some, but it’s not as good as it was on the Chrysler 300, and high-beams are not always an option, so the normal lights should work properly. The IIHS recently tested headlights, and the Hyundai Sonata was among the worst (Genesis wasn’t tested), and here is the kicker: “Among the 44 headlight systems earning a poor rating, the halogen lights on the BMW 3 series are the worst. A driver with those headlights would have to be going 35 mph or slower to stop in time for an obstacle in the travel lane. A better choice for the same car is an LED curve-adaptive system with high-beam assist, a combination that rates marginal.” There’s more on the topic here: http://www.iihs.org/iihs/news/desktopnews/first-ever-iihs-headlight-ratings-show-most-need-improvement
I have the ivory (in Germany “crème”) interior – it looks great, but my driver’s seat showed dirt after less than 3,000 miles, my Chrysler (beige) never showed anything on the seats. I work in an office (as opposed to a construction site where dirt would be part of the job), and don’t wear jeans usually – still noticeable dirt on the driver’s seat. I also think that the dark wood that comes with the ivory interior doesn’t contrast with the dash – it’s black on black, so the wood looks like it’s part of the plastic used on the top of the dash. A browner or greyer wood might have been a better choice in my opinion.
OK, since I just listed a bunch of things I dislike, here’s stuff I do like.
Exterior design is very nice, distinctive (like the Chrysler) without being too derivative (like the first generation Genesis in my opinion, it looks like a Mercedes too much). It stands out in a sea of Honda Accord’s, Toyota Camry’s and other bland cars. Of course, most people here in TX have pick-ups or SUV’s (Chey Suburban’s – the Texas Cadillac), but the car stands out in a good way.
I love the Ibiza Blue color, even more than my blue Chrysler 300. Best color for the Genesis, no question. It’s faster, better, nicer, and more beautiful than all other Genesis colors combined (I had to write this, because everybody on this forum claims their color is just that).
The interior is nice – better than the Chrysler 300 by at least one level, not on par with the latest Audi products though.
The HUD (heads up display) is the freaking dog’s bollocks (that’s English – not American – I picked that up when I lived there and drove a Peugeot 205 Diesel (non turbo) – slowest car ever, if you disregard the Beetle and the 2CV). I love, love, love the HUD - I wouldn’t want to have a car without that feature in the future, and the one in the Genesis is beautifully done.
Ride is quite and comfortable – with the exception of the before-mentioned vibrations that should hopefully be addressed by the dealer soon.
The price is right, my lease payment for a fully loaded Genesis V6 (except AWD) is less than my loaded Chrysler, even though the list price was $8,000 more for the Genesis.
Overall, I have the feeling that someone at Hyundai created a list of features found on competitor’s cars (I assume Lexus, Audi, BMW, Mercedes-Benz and maybe some tier 2 luxury cars like Acura, Volvo, Infinity, Cadillac, etc.), was given a size and price point and they started designing a car around that. It checks most of the boxes (with a few omissions like adaptive lighting, and some other features), looks good (thanks to the Audi designers they hired), drives well - but to me it lacks that last bit that makes it a true luxury car. It feels like my 2005 Audi A6, built to the standards of the last generation of luxury cars, not the current generation. There’s no innovation, it’s somewhat derivative: The Audi MMI or BMW iDrive like controls, the list of features, the materials and to an extend even the exterior design – all similar to the last generation of German luxury. At a much better price point.
But at the same time, some things don’t seem to have been thought through to the end. The engine (bad mpg and not a screamer, although Hyundai has the 3.3 Turbo now), the center console controls, the lack of memory features for some functions I mentioned above, the creaking sunroof, the wheel vibrations, small things that add up to give me the feeling that they just haven’t arrived yet.
The Genesis is a good car – a good car at a very attractive price. It’s not a great car, or an innovative car. It’s worth the price, but some here like to compare it to the Lexus GS, the A6, the E-class or 5-series, and it’s just not on the level of the latest generation of most of these cars in my opinion.
Like you, I don’t want to spend the $$$ for a new German luxury car. If I didn’t lease, I would rather buy a CPO (certified pre-owned) Audi A6 than a new Genesis – for the same money it would be no contest in my book. But I can’t lease a similar German car (it’s hard to find leases on used cars) for what I pay for the Genesis. The Audi A6 I want is US$72,000 list price (or about Euro 80,000 for an almost fully loaded 3.0T Quattro, quick as hell, beautiful too), which is $20,000 more than the car I have right now.
Have you looked into re-importing a German car from the US? I think prices here are much lower for the same vehicles, and I sold my previous VW Passat to friends who moved to Germany and registered the car there. It wasn’t all that complicated, and might be an option. I’m sure the Web is full of guides and probably even professional importers. I would also consider purchasing a CPO Germany car, there must be a lot of lease returns from all these company cars. I’d look for one with low miles that was treated well - that worked well for me when I purchased my first Audi in Germany back in 1990 or so. That was a well-equipped company car lease return, and at a very decent price. The down side of used cars is that you can’t custom order colors/interiors, but if you have patience you may find exactly want you want. I’d look for a nice Audi A8(L?), they depreciate a lot, are huge and often have a lot of options. Not cheap to maintain though.
The Genesis seems to have been designed for the US, the middle east and maybe China – I think it will never be a big seller in Europe. The engine is too thirsty, the car is generally too big, and I would worry about dealer service (the mechanics just won’t get the experience on the car with only a few hundred sold in Germany) and parts supply. Even here in the US certain parts seem to be hard to get, someone on this forum reported there was only one set of brake parts available in all of the US when they needed something replaced under warranty.
OK, this is now a short novel, and I could probably go on for a while longer as I think about things. I don’t want to sound negative about the Genesis, I would probably not discourage someone in the US to get one as much as someone in Germany, but you do see quite a lot of Geneses here in the US – they sell over 10,00 of these here in a year (stupidly, Hyundai reports Genesis coupe and sedan sales as one number).
I hope this was somewhat helpful – it was certainly long, let me know if you have any more questions …
I'm enjoying the German/US chat. I lived in Berlin for two years as an Army officer. Bought a BMW through the PX system. Enjoyed it while living in Berlin and then back in the US. It rocketed to 60 in about 10 seconds and hit 79 in the quarter mile.
It was a lemon in the end, but a wonderful driving machine. I eventually traded it in on a Pontiac. Much more reliable, but no fun. Back in those days, most Americans thought BMW was BRITISH MOTOR WORKS. I loved my BMW 2002.
Currently shopping for a replacement car. Down to a used certified 2014 Lexus GS350, 2016 Genesis Ultimate V6 and a 2016 Dodge Charger V8 Road/Track. The Genesis has the highest residual value (and a $5k bonus for leasing). The Lexus is the sportiest and feels lighter, but options are extremely limited compared to the Genesis, the Dodge is marked waaaaay down, has brute V8 power...just worried about reliability.
I'm expecting a settlement check, which has my hands tied on a purchase. So, I'm stuck waiting, hoping that Hyundai continues the sales deals. My credit is crap, so I'll most likely have to pay the lease payments up-front.
Welcome aboard! And thank you for signing up. Yes, reliability and bad service are to be expected with Chrysler products. I've been there. The Lexus GS350 will be extremely reliable and service will be as good as you can get. The Genesis Sedan fits right in the middle. Depending on price, that might be your best deal. Customer service is hit or miss at most dealerships and reliability is actually pretty good...
Gesundheit!
Dankeschön! ;-)
brakes - excellent
The V8 isn't available in Europe. The v6 is thirsty enough... a gallon of non-premium gas currently costs ~6 USD in Germany...
Good to know, thanks. My Chrysler is pretty accurate - only get around .5 variance on the real world mpg
Thanks for the clarification.
This leaves the question how the car will get its traffic data. The (rather crappy) TMC Service distributed by FM radio will shut down in ~20 months here and according to the dealer the car has no online integration whatsoever. So no Google search as well.
wow nice! I really liked that on my old chrysler! Hyundai Germany really should do a better job advertising the system... you find next to nothing on their website about the multimedia unit.
I've sent an inquery to the dealership about this. Thanks for bringing this to my attention. My new car should most defineately be an UPGRADE in every aspect.
I was able to enter an german address during my testdrive with the following sequence:
"Adresssuche" (Search for an address) -> "München Hauptstraße Drei Zwei" (Munich, Street name, Three Two)
That worked pretty well. Odd though how you have to read out the separate digits for the house number.
hehe yes it is. as well as the double-tap the lock button for a short horn sound...
Hm too bad. I figured since the video showed a google search it would have an integrated web browser and can be paired with a smartphone to allow for online services. Looks like the car has no online capabilities whatsoever here which is a HUGE letdown in terms of navigation since you cannot search for POIs with google nor get live traffic data.
Read about that in the forums. Seems to be tire related as you said. I've noticed nothing like that during the test drive :)
Didn't notice this as well. Was sitting in the car for about 15 minutes with the engine running and the AC on to set the mirrors, pair my phone etc.
Have to agree here´. The 300c does this way better. I have issues locking the car though... after I exit the button does not respond for about 2-5 seconds on my 300. Really annoying if you are in a hurry.
LOL one of my very first thoughts: "Oh gosh how stupid is it to have TWO cigarette lighter ports and an usb port in that tiny storage areay" You and I, good sir, think very much alike :)
Have to agree here as well. The overall output is good but that's it. Especially lower frequencies tended to blur during my test drive.
I have the Alpine Sound System in the 300 which performs a little bit better. The best system I had so far was in the 2010 Chrysler 300C SRT with the boston premium system.
Hm had no problem with this :)
Wow that sounds like really bad design. I'll check with the dealership about this. I'll be driving in ECO mode for 99.9% of the time and will also have the auto hold thingy enabled. Isn't that coded to the keyfob?!
Thanks for pointing this out! Most definitely have to drive this car by night then before I buy. I had a similar issue while test driving a Opel Insignia over the weekend which praises itself for "best in class headlights". You couldn't see more than 25 meters then the light cone would cut off. Dealer was surprised since "no one ever complained about that before" but that probably was just the usual bullsh*t respone ;-)
Other way around here... while I payed ~33k USD for the fully loaded chrysler with every option the Genesis is tagged at 72k.
How would you compare the ACC from the Genesis to the Chrysler System? (Apart from the fact that the Chrysler system shuts off at 15mph) During my test drive (~60 minutes) the ACC system performed well but you'll never know... ;-)
Well I've actually looked into importing a 2016 Chrysler 300 but that's just insane in terms of taxes. My main issues with the german brands, especially Audi, is, that their ride is much to sporty for my opinion. Plus their interior is absolutely mundane. I love the kind of emotion the brown leather plus open pore wood of the 300c unleashes.
It most definitely was! Thank you so much for going into detail!
:D
Austin -
Keep on the dealer about your vibration. Do you have Michelin MXMs? I went through 2 sets of those before finally getting a swap to Conti DWS. That solved the problem.
Regarding the aim of the HIDs, you are correct, they are correctly set to the Hyundai spec, which is totally too low. I spent $20 at a local shop, they raised them, and now it's much better. I don't get a flashes from oncoming traffic, and I can see down the road. I agree that we should not have to deal with that, but apparently, this is a pretty widespread industry issue. One of the Insurance Institutes did a study on this, and for some reason many cars are spec'd with this low aim.
I also had the complaint regarding the radio vs. the climate controls, but after about a month I got used to that.
Getting the vibration solved may take some persistence, but it's worth it. Make the tech drive, and also try other G2s. Some (Most) don't vibrate. Part of my diagnosis involved my tech swapping wheels and tires from a car that did not vibrate. When they did that, the problem went away, and the dealer convinced Hyundai to fund the tire swap.
You will still get a bit of flat spotting from most any low profile tire, but that goes away in a few miles. You will also have some road feel, which IMHO is a good thing. That will be dependent on road surface. Again, the car is a joy to drive once now that mine is fixed. I hope you can get the same outcome.
Just got the info that Hyundai will release the Genesis at the end of the year with a 4 cylinder 2.2l diesel engine with 147kw (200ps)
Now that's awesome news!
another example of how the market views the genesis sedan on the same level as a chrysler 300.
and the reason why they don't sell till they are the equivalent price of them as well.
Awesome. Thanks for the insight. It looks as if Hyundai is contracting the number of dealers to 4 here in Dallas for the Genesis line, which is a good thing. The GS350 is awesome, especially with the F-Sport package. Problem is, they don't have "packages" like Hyundai does guaranteeing equipment per level but rather choosing individual items. Makes for difficult negotiation and ability to find a car. As for Dodge/Chrysler, I'm wary of their products. They have 2015's still on the lots here with HUGE markdowns. V8 is the obvious choice, since the V6 seems so underpowered...but there is a fuel penalty. I couldn't see myself ever owning one, as I don't have a desire to know the Service Dept staff by first name.
It seems as if the majority of those here are driving V6 models. Any regret not getting the V8? Are most leasing? I've been told this thing is a beast to work on, pretty much requiring you to get it fixed/maintained at a dealer. There doesn't appear to be any financial incentive to buy a Certified car. Thoughts?
Hello, Glen and welcome to the forum. I bought (as I don't lease) my 3.8 Genny from Rockwall Hyundai. The V6 has excellent performance and reasonable fuel mileage. I wanted a luxury cruiser and that's what I got. I have no need for the extra cost, weight and maintenance for the extra speed that I do not need. All modern cars are difficult to work on and the Genesis is no different.
I have been very satisfied with the dealership. It's a small local dealer with no pressure sales and excellent service department. I do recommend that no matter which dealership you use, have your salesman introduce you to the service manager and advisors and do get their cards. Knowing them by name is a good thing when you do need warranty work (remember the long warranty) or routine service.
Zero regrets on not getting the V8.
It's a sweet motor and for those that really want a V8 nothing else will do but for me:
1) while it is faster the V8 never FELT that much faster to me in back to back drives. The V6 has never felt underpowered to me - certainly not in comparison the the GS 350, which was my second choice. Now if you're coming from a V8 or a blown 6 then probably you will want to stick with that level of power.
2) that extra weight over the nose is something I DID feel all the time - at least when turning or braking;
3) this car is enough of a fuel pig in V6 form. V8 is worse yet and drinks pricier juice
4) if you're in the States, no AWD with the V8.
Coming from a Chrysler 300 with the V8 hemi engine, I can tell you my Genesis V6 isn't as fast but certainly isn't no slouch either. Sometimes cars can have too much power and torque in a dangerous way which is something I don't have to worry about anymore. Furthermore, I had a Buick LaCrosse when the newer model first came out. The car was big, heavy and came with a big V6 motor. If I stepped on it hard, I never knew if I was going to get the rocket or the turtle. I don't have this problem with the Genesis. If we could get the V8 in AWD, I most likely would have purchased the bigger motor. But I have no complaints with the V6 in terms of power and the ability to get moving fast.
I do like the Lexus GS as well. I think it's a really nice car and I love the minor update they just did to it - especially at the tail lights. It's a great luxury sedan.
As for the V6 Genesis, no regrets. Especially considering I saw somebody "pulled over" by a old pickup truck yesterday. I'm kinda glad I don't have a fast car anymore. And the V6 is perfectly adequate for me. Hearing the performance numbers before I bought the car - I thought it would be slow. It's not...
Just talked to the dealership about online services and they told me that the car can be connected to a Wireless Hotspot to enable Tom Tom Live Services plus online weather and traffic. I am very sure I did NOT see any option for this during my test drive nor can I find any information about that on their website.
Could you please go a bit into detail on how this works? :)
Thanks!
Last question... I have the choice of a 2015 Genesis V8 or 2016 Genesis V6. Both with similar mileage and exact same price. Does the V8 really "gulp" fuel compared to the V6? I checked Consumer Reports and it looks like the prior generation Genesis engines were 1 mpg different. I think I could live with that.
As a side note, I spoke with my Lexus salesman and he can't get a certified 2014 GS350 similarly equipped any where near the same price as the Genesis. Can't see spending $45K on a 3 year old car with 40,000 miles.
