folks,
this is for those of you that have an htrac genesis and therefore headlamp washers. if for some reason your washer fluid disappears from its reservoir very quickly you might wanna check and see if there is a leak under the headlights.
i recently filled up my reservoir after getting a low fluid light. i used the windshield washers ONCE, and the low fluid light came on almost instantly. i was like WTF! so, i opened the hood and ran the washers again. low and behold nearly a gallon of washer fluid blew out on to the driveway right below the passenger side headlamp! well, i took the car in to the dealership and of course the hose that runs to the headlamp washer had come off. i guess the clamp hyundai uses on that hose to secure it is kinda small. apparently the other headlamp clamp was nice and tight.
anyhoo, just a head's up in case you ever encounter magically disappearing washer fluid and are not sure why!
interestingly enough nobody in the service dept had a clue that some of the genesi have headlamp washers!
