Rey
The high beams on most Genesis are illuminated with 55wt. H7 bulbs. These are the "legal limit" bulbs. Contrasted with the HID low beams, the high beams are dull and dim.
I tried aftermarket Oshram 100wt. H4s. Not a great choice. Beam was still yellow. Perhaps the system was overloaded with the 200wt loading and needs a relay to be optimum.
Just installed an LED conversion kit form www.headlightexperts.com. This is not a commerical for them, just naming my source. Whatever, I am very pleased with the result - now the high beams are same "color" as the lows and really cover the road ahead.
I did pop for the $10 extra which negates warning lights and recommend it.
Installation is not a "breeze". You need to remove the front engine compartment cover. Even then access is poor. So I removed the airbox on one side and moved the big fuse box on the other side.
The LEDs come with a large harness "tail" which can be stuffed into the headlight cavity with some imagination.
