BobbyC777
- Jan 22, 2015
- Location
- Pinehurst, NC
Today I changed the air filter in our 2011 4.6 sedan for the first time since I have owned the car. All went well until a foam filter which is normally attached to the inside of the cover fell out. This foam filter has the same footprint as the main filter but is considerably thinner. I noticed that it appeared to be held in place by a very thin post at each corner of the cover. But the 2 posts on the driver side had broken off. So without those posts it was hard to reattach this filter. I ended up putting some non-bonding mastic adhesive in those 2 corners and that gave it enough grip to stay in place while I reassembled everything.
Does anyone know if those 4 skinny posts are all that normally holds this upper filter in place? I'm all set now for a few years but I'm just curious as to how it is supposed to be attached.
Thanks!
Thanks!
