Sway bar end link "popping" on Ark Springs - replacement?
TylerDH
Omaha NE
Has anyone that is lowered replaced your Sway Bar End Links? mine is "popping" and i need to replace it. i am thinking adjustable instead of factory. any input would be appreciated.
- - - Updated - - -
rear sway bar, sorry.
did you have to remove the rear sway bar for installation? are they loose? if the nut is lose it can rattle.
no, i didn't remove any of it. the nuts are tight, they just pop with pressure on them...
Sounds like ball joint wore out, easy enough to replace. As for adjustable you can get them and mess around and see how you like the difference, but these cars are heavy and when you get the back to swing around it goes.
