QuantumRift
Having lived in SE ARizona for nearly 25 years, HEAT is the KILLER of batteries. 100+ air temps, and heat coming off pavement when idlingin traffic at 200 deg or higher....HEAT is the killer. HEAT. Cold weather only slows down the chemical process the battery uses to produce electricity, but a failing battery with iffy internal connections and shorting/bad/open plates will die a slow death.
I believe you are talking about 'sulfation'...and that occurs in a (lead acid) battery when it is deprived of a full charge.
What is sulfation? During use, small sulfate crystals form, but these are normal and are not harmful. During prolonged charge deprivation, however, the amorphous lead sulfate converts to a stable crystalline and deposits on the negative plates. This leads to the development of large crystals that reduce the battery’s active material, which is responsible for the performance.
There are two types of sulfation: reversible (or soft sulfation), and permanent (or hard sulfation). If a battery is serviced early, reversible sulfation can often be corrected by applying an overcharge to an already fully charged battery in the form of a regulated current of about 200mA. The battery terminal voltage is allowed to rise to between 2.50 and 2.66V/cell (15 and 16V on a 12V mono block) for about 24 hours. Increasing the battery temperature to 50–60°C (122–140°F) during the corrective service further helps in dissolving the crystals.
Permanent sulfation sets in when the battery has been in a low state-of-charge for weeks or months. At this stage, no form of restoration seems possible; however, the recovery yield is not fully understood. To everyone’s amazement, new lead acid batteries can often be fully restored after dwelling in a low-voltage condition for many weeks. Other factors may play a role.
A subtle indication whether lead acid can be recovered or not is visible on the voltage discharge curve. If a fully charged battery retains a stable voltage profile on discharge, chances of reactivation are better than if the voltage drops rapidly with load.
It's also helpful to know that the electrolyte freezing point in a FULLY CHARGED battery is about -76 deg F. A battery that is discharged, can freeze at 32 deg F down to maybe 10 deg F. When it freezes, the water in the electrolyte will expand and can crack the case or expand and break connections and bust connections across the plates. And the truth is, that there is only a very small difference between a FULLY charged battery and a DEAD battery. If you want to learn more, check out Battery University:
Measuring State-of-charge - Battery University
Quant
Quant
You are correct, cold weather reduces the cranking ability of a battery but they don't actually generate electricity they store energy that was generated by the alternator and stored in the battery.
The most common causes for a battery failure are from sludge build up and stratification. Sludge builds as a battery ages and goes through cycles of charging and discharging the plates shed material and this builds to a point where it will create a short and cause a dead cell. Stratification is when a battery has not been charged correctly at a high enough voltage or has been sitting and the acid actually separates from the water creating a weak solution on top and a reduced storage ability.
The only real difference between flooded cell and AGM Batteries are that instead of a liquid the water acid mix is basically in a fiberglass mat like a sponge. This configuration is to minimize evaporation, self discharge and stratification issues which is why they handle deeper discharges and heat better than a flooded cell battery.
I know there are deep cycle (thick plates), cranking (thin plates), marine/hybrid (medium plates) batteries but you got my attention with the North/South batteries, this is a first for me as I have never heard of such an animal.
