need4spd
- May 24, 2016
Just wanted to let you know I found a solution for my 16 rear window issue (would not roll down).
Seems that playing with the child rear window lock (pushing a number of times to turn on and off) resolved the rear windows from not rolling down (yes, I had tried turning it on and off before one or 2 times without any luck when it first happened), but this time it took like 10 or more pushes in succession to get them to work.
Seems like the contacts in the children's switch got dirty / had corrosion on them, pushing the switch "cleans" the contacts so they must have had a lot.
My symptoms were at first the drivers rear would not work and there was a fractional second delay in the pass rear window going down. Then both stopped working.
It was like that for a month or so before I thought it might be related to the children's lock on the windows and decided to push it a number of times, and then they started working again.
Worth a try for those having the issue.
was waiting on the next service to have the stealler check them. One less thing for them to mess up now.
