Car shaking when idling?
Lisams98
1G Genesis Coupe (2009-2016)
Have a 2011 coupe 2.0t and I’ve noticed when the car is in drive but idling, on the brake, or moving the steering wheel a little bit makes the car pretty much like shake?? Anyone ever have this problem? Worse with A/C on too
sounds like a bad motor mount.
That’s what I thought but I Got those looked at, mechanic said they were fine. He thinks it might have something to do with the computer?
clogged or bad fuel injector.
need to have it scanned to see if there are any codes. otherwise it's just shooting fish in a barrel.
No codes came up, going to start with a tune up to see if that solves the problem and go from there. Thank you!
Tune up didn’t do the job so any other suggestions???
what did the tune up consist of? did you check the injectors?
