ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
Let me start off by saying that my Selling Dealer Service Department is GREAT. Their Genesis Technician and the two Service Writers I work with are great, and they all treat me like a king. I have issues with the guys at the Hyundai Tech Line in California, who get contacted by local dealer technicians. I've seen this before, (with Honda) and now I'm seeing this with Hyundai, and the things they want my Genesis Technician to do to correct my "issues". Last thing they wanted my Tech to do was to make sure all the electrical grounds were making good contact and tight. If Tech Line can't give good information to my dealer tech, who can?
1. NO AUDIO - The one issue that MUST BE FIXED, (and I know that Hyundai Tech Line knows about it because others have had the exact same problem) is sometimes, when I start the car, the Audio does not come on. No AM/FM/CD/ETC. In order to get the Audio to come on, the ignition must be shut off, for a few minutes. After a few minutes, turn the ignition back on, and all Audio again works as it should. (If ignition turned off, then back on right away, the Audio stays off). This is something that MUST BE FIXED because the audio for the Bluetooth also will not work, and if I get a phone call, I will not be able to hear the person who calls me. Never happens on first start in the morning, but only after the car has been sitting in the sun and something "heats up" causing the malfunction. (Amplifier in trunk hot trunk?????) This it the most important thing that MUST BE FIXED.
2. NO DOOR UNLOCK WITH DOOR BUTTON - This issue is one that I can live with, but SHOULD BE FIXED. Others have had the same problem. When I go to unlock the car using the button on the door handle, nothing. No "beep", no unlock, nothing. To unlock the car, I must either dig into my pocket, get out the key fob, and hit the unlock button there, or go to the passenger side of car and unlock from passenger door button, or use the emergency key that slides into the key fob. This is now happening often enough (and it is happening OFTEN) that I see a pattern. Always happens when car is PARKED IN DIRECT SUNSHINE, and the SUN IS DIRECTLY ON DRIVERS DOOR. I'm sure that the controller, inside the driver door gets over heated and causes the problem. Again, I can live with it, (or always park with the door in the shade <grin>), but it SHOULD BE FIXED.
3. I've had other things happen, but I can live with them as they are rare, and correct themselves quick, without having to wait a long time.
Yesterday, I phoned my favorate Service Writer and "suggested" that he have the Genesis Technician contact Hyundai Tech Line in California as I had both the problems show up yesterday. BOTH PROBLEMS, and I'm getting tired of the lame things Hyundai Tech Line comes up with. Dealer techs can't be expected to see, or know all the problems that show up in various cars, however manufacturer Tech Lines "should" know about all the problems that dealer techs questioned them about. I know my dealer Service Writer, and/or the Genesis Tech will phone me whatever they learned. They've done it before, and like I said before, they do treat me like a king.
