mtrot
- May 20, 2013
- Location
- East Texas
- Genesis GV80
Well, I've messed up pretty badly. While trying to remove the 3rd plug on the passenger side, the socket extension made contact with the one of the electrical cables that comes from an electrical supply box on that side. (I took the cover off of that box because the cover was making it difficult to get the socket and extension down into the plug port.)
Anyway, there was a big spark and crackly sound. I was about finished changing the plugs, so I went ahead and finished with that.
But now the car will not start.
Some lights and functions do work, while others do not. I checked the two fuses that are located near the positive battery terminal, but they do not appear to be blown. There is a fuse associated with the cable that sparked, but I cannot tell if that fuse is blown.
The brake lights, steering wheel telescope and tilt function, fog lamps, LED accent lights, interior trunk light, interior "dome" lights, and power fuel access door all work. The actual headlights do not work, nor do the emergency flashers. When the door is opened, the interior lights do not come on, despite the DOOR button being depressed. Does anyone know if there is another fuse somewhere that is supposed to blow if something like this happens? Any other ideas? Thanks much.
