A/C vents not working
tbently
SUSTAINING MEMBER
Houston, TX
I have a 2015 G 3.8 with 60K miles that has suddenly, intermittently , not blowing air through the center 2 A/C vents. Outer one's work fine. If I turn of and restart the car the center 2 vents work fine! Any thoughts?
There are dampers inside to direct air flow. Good chance that the actuator that opens and closes them is not working. While that is a common problem with all cars as they age, I don't know why restarting makes them work. What you may want to do next time, instead of restarting go to the screen and manually go from floor to dash and see if that opens them. Possible they are not getting a signal.
