AC System
TxGenesis01
Is there a way to make the rear ac temperature always match the front temperature?
In the climate control section, you can only turn on/off the rear vents.
I think putting the temp wheel in the middle follows driver setting.
No, that did not work. The rear temp did not change as i adjusted the front temp.
I think they are independent of each other so the rear passengers can select on their own. You may want to try turning it off if you don't usually carry anyone in the back.
My issue is that im using a baby car seat, so the controllers/wheels are no longer (easy) accessible.
It's nice that the car has independent rear/front control but it is a design flaw if there is not a way to sync the temperatures.
The rear controls are very basic in the Genesis. You have to adjust the rear temp by feel or maybe use a infrared thermometer to dial in the correct temp you may want in the rear area. I actually dislike the rear control design as well. I usually have it set to off and let the front vents adjust the cabin temperature automatically.
I just went out so I looked further on my G80 Ultimate. There is a screen for climate control and you can select the auto defrost. There is a line for syncing the rear, but it is grayed out. I don't know if the G90 has it. Looks like they thought about it but cheaped out, at leas in the US market.
