2009 Génesis telescopic steering wheel
Gareso
I recently bought a used 2009 Genesis as is. Two days after the purchase, the telescopic steering wheel stopped moving in and out like it was doing before. The switch on the side of the column only works going up or down, but it won’t work to make the wheel go in or out. When the ignition is turned off, I can hear a noise coming from behind the dash, like the telescopic mechanism is trying to work but it won’t move. Please help me figure out this problem.
I'm having the same issue. Any help would be amazing
Limit switch or gears worn out. do a search on this forum and you should find the fix info. As I remember it is an expensive fix. sometimes the entire steering column had to be replaced.
Yikes!
Thanks for the info. I'll probably just leave it then.
