Rear Roof Glass Wing Spoiler.
Nikhil Malhotra
The rear roof spoiler seems to stick via 3m tape. Thats fine.
How is the LED Supposed to work ? Where to get the power supply so that its synced to the car brake.
Its on ebay - but they do not mention any instructions.
19626
19627
19628
I believe it is the OEM LED that is there lit up under the wing and reflecting off the top of it
19629
I got the answer from the seller . Its looks a bit crazy - specially when i see the drill on the glass in the 2nd picture.
19630
That is not a drill, that is a heat gun.
Steps seem fairly simple
1. Clean surface
2. Heat area up
3. Position wing
4. Peel off double sided tape
5. Apply pressure to wing to ensure adhesion
6. Run power wires along side of glass; lift seal up and run wire thru/under
7. Tap into brake OEM wires
8. Viola!!!
brake not break..
however, having had a 3m tape mounted window wing on my Chrysler 300C and have it fly off at highway speed and smack the car behind me, I will never put one on my car again.
Have’ta agree with Mr.I !
I had a rear window spoiler, and there shouldn't be any LEDs on the wing itself. Rather, there's a cut-out on the underside of the wing so that it doesn't block that existing OEM LED brake strip. But, to add what someone already said, the 3M tape alone WILL NOT hold the wing for very long. Mine started coming off after a few months. The wing is going to need some molding at the ends, as well, as something extra in addition to the 3M to adhere REALLY well. I've had my roof spoiler in the closet since last summer, and will be putting back on this summer. WISH ME LUCK!
the problem with the 3m mounting style is the heat from the sun on the glass will melt the adhesive and it will loosen or come off. made worse by the fact that it is so large of area and the spoiler is flexible so not all of the tape actually makes contact with the glass surface.
there are adhesion promoters that are supposed to help make the adhesive stronger and stick better, and the heat gun also helps promote the adhesion, but again the sun and time will cause it to peel back up.
