carguy75
- Jun 23, 2018
- Location
- Atlanta, Georgia
- Genesis Model Year
- 2015
I have decided to install a 15in Power Acoustic subwoofer in my Genesis to gain a bit more low end sound. The stock system sounds good to me but the bass response is fairly weak with the stock sub.
I am collecting the items needed for the install such as amp kit, line out adapter, and some tap screws.
I originally was thinking that I had to tap an signal wire from the rear deck subwoofer that requires me to remove the deck deck panel(and rear seat), however I learned that the stock amp is located in trunk behind the trunk liner on the driver side. Therefore, I would only have to tap the wires that send the sound to the stock subwoofer which makes this install much easier than I thought it would be. I would be able to do the entire sub/amp install inside the trunk area since the battery is also located in the trunk as well. The only panel I would need to remove would be the trunk liner/trim panels.
I will only set the amp crossover to send the subwoofer a really low 40hz signal so that it only provides a low end response that I can feel in the driver seat without being "boomy" and overpowering the rest of the sound from the other speakers.
I used this subwoofer in another car(2005 Mercury Montego) in the same fashion to boost the stock premium sound system with weak 6X9 subs in the rear deck. The sound was amazing, clean and solid.
I will do a DIY on the install for anyone else who wants to add a subwoofer to the stock Genesis system.
The sub mounted in my old 2005 Mercury Montego AWD Premium
How the sub looks in my Genesis trunk when I test fitted it.
