Setting up service (valet & warranty work)
FrankieD
Atlanta, GA, USA
Hi,
I just got my car on Sunday and already noticed a few things that need to be looked at...
- lane assist turning off midway through a curve
- CarPlay cutting off
- left side bolster doesn’t seem to be getting as tight as the right (also, does the passenger seat bolsters also first up when putting in sport?
- some small ‘cuts’ in the rear driver side window
- rubber window seal bent under frame and has pinched areas because of that
Since I’m new to all of this, could someone please advise me on the process of setting up the valet service and warranty work that needs to be done? Thanks
Congrats on the new G70. I don't know where you are located but if in the US then contact your dealer or any dealer that is within 50 miles of you if you have a different preference on dealer. If you are in Canada, then I'm sure someone will be along shortly to give us that information.
Sorry should’ve specified. I’m in the US.
Perfect! Thanks for the info
make a list and call the service department. Don't rely on the app to do it. Some dealers are better than others with scheduling.
Thanks. I will wait a couple weeks before I call. Hopefully I won’t be adding the the list
