rockettman81
- Aug 29, 2018
I have a 2009 4.6L with a over 160k miles on it and don't know if the trans fluid was ever changed by the previous owners. I do know that I have a very jerky downshift from 2nd to 1st a lot of times right before I come to a stop. I'm hoping a drain and refill solves the issue. I've researched some different fluids and this fluid is noted as compatible with our transmissions, is priced better than most compatible fluids, and it gets good (although limited) reviews: Amazon.com: Ravenol J1D2110-004 ATF (Automatic Transmission Fluid) - 6HP Fluid for ZF 6HP Transmissions (4 Liter): Automotive
I'm very much an amateur/newbie at this sort of thing, so I'm looking for advice. First, I want to make sure I have the procedure correct:
1) Have car level before starting
2) With catch pan ready, remove the fill/overflow plug
3) Remove the drain plug
4) Let fluid drain out until it stops draining
5) Replace and tighten drain plug to spec
6) Fill up fluid via the fill/overflow plug, using a pump, until fluid starts dripping from the fill hole.
7) Replace the drain plug, but don't tighten to spec yet.
8) Start the car, shift through each gear (including the sport-shift gears), pausing at least 5 seconds in each gear
9) With the car still running, remove the fill plug one more time and add additional fluid until it starts to spill out again
10) Once fluid starts spilling out again, replace the drain plug and tighten to spec
11) Run through the gears one more time and take the car for a spin....that's it
Thank you all in advance!
- Are those steps correct?
- How can I jack the car up and get it level on jack stands? Specifically, there are "pinch welds" right in front of the rear wheels and right behind the front wheels, right? BUT, I can't jack from the pinch weld and then put a jack stand right next to where I'm jacking, can I (so that I can move the jack to another corner)?
- Is there a single jack point where I can jack up the whole back end at once (and put a jack stand at each of the 2 pinch welds near the rear tires)?
- Is there another single jack point in the front to jack up the whole front end at once (and put a jack stand at each of the 2 pinch welds near the front tires)?
- Can you help a dummy like me find those jack points?
- Also, I did some looking on the driver side of the transmission pan, and I'm confused....I might be missing a couple of bolts....one of which looks like it could be important. If you look at this video ():
- Is there a bolt missing that is supposed to be holding that piece in at the ~0:55 mark of the video (zoomed in at the ~1:11 mark)? If there is supposed to be a bolt there, any significant issues with it not being there?
- Perhaps more importantly, is there a bolt missing at the ~1:30 mark of the video (zoomed in on at the ~1:37 mark)?!?! If there is supposed to be a bolt there, does that mean I have transmission fluid splashing out of that bolt hole?!?!?!
