YaBoiKev
- Sep 12, 2019
- 1G Genesis Coupe (2009-2016)
the car seemed fine when I first turned it on this morning then after I drove a little bit I turned the car off and then about 30 minutes later I turned it on, started to idle rough and popped the code again of a misfire in cylinder 3 but last time it was 3 and 2 then from the drive from my house to my cousins house was okay till I started to drive normally the temp went up and the after I started to drive slow (below 3,500 rpms) it went back to normal temp and then went on high when I was idling at a red light but then went back to normal as I started driving. I tried turning the heater on and it seemed to to blow cold air then the temp went high again, as the heater was blowing and I was driving it started to blow hot air (NOTE: this happens on and off I don’t know why) and then the temperature regulated to the middle. What could be causing this?
