pcv valve replacement 2014
do it yourself
Equus (2011-2016)
I had the emmission error light pop up on my 2014 Equus. The dealer believes it is the pcv valve. They recommend pulling the intake manifold and heads, has anyone else experienced this? The estimate for this is nearly $5000. Is it possible for someone with moderate mechanical skills to do the pvc change out?
I don't know where the one on your car is, but it is a relatively simple job. No, it is not a $5000 job. WTF does he want to pull heads for? Find a good independent shop to do it if you don't want to.
Here is some basics on what id does.
Bad PCV Valve Symptoms and How to Test the PCV Valve Yourself
Ed
Thanks for the advice, will look for a parts diagram or a local shop to do the work.
