Battery Maintainer
tompass
SUSTAINING MEMBER
SC
Where is the location of positive terminal under the hood for connection of battery maintainer or must it be connected directly to battery in trunk? I see the red + at rear of fuse box location but no readily identifiable connection point.
I wondered about this also. There is an exposed metal clip-like thing that appears to me to be the positive connection but it is so close to the rest of the fuse box items it is not a secure location.
The positive terminal is accessed when you pop open the fusebox located in the upper left corner of the engine bay. It has a red "+" sign on the cover. When you remove the cover, you'll see the metal prong sticking out that you can attach the positive connection.
The negative terminal is located just beside the passenger side airbox, it looks like a long bolt, attached to the body, and sticking out into the engine bay. There is actually a "-" sign stamped right next to it.
Circled in red...
OR, you can always just access the battery directly from the trunk if needed.
Thanks. I was aware of the negative location but when opening the fuse box the metal prong/tab looked a little flimsy.
Yeah, it does appear somewhat derpy. Haha.
Looking at the distance between the + and - terminals in the G70 I realized that the cables from my portable jump starter (sold by Amazon) are too short for reaching both poles. I will have to use another bolt attached to the frame or find an extension cable to reach the negative terminal or attach the jumper directly to the battery.
Or I will use this technique
Yes, I was surprised at how small the + terminal was. I don't think a typical jumper cable will be able to grab and hold onto this very well. They're designed to grab larger things. It also seems too close to other things.
Man, those AK's can do anything! Haha
