Now that I know where the proximity sensor switch is, I note that if I turn it on as I enter the garage usually, but not always, the front proximity warning works without having to go into reverse..
Still don't understand this system. As stated above it seems to be for parking only and they assume you put the car in reverse start to park which will activate the system. It seems like the front proximity warnings automatically shut off as you drive. Does this make any sense to anyone and why would they do this?
Yes, they are for parking only. They shut off as you drive so you don't get false reading from stray RF signals or a car in the next lane.
You should not have to turn the switch on as you enter the garage. If it is in the ON position they should come on every time below the threshold speed. If the switch is on, they should work every time. Mine do every time. If I pull into a parking spot they will go off from another car in the spot in front or the curb or stop if there is one. I back into the garage so it always works in reverse.
From the manual:
Operating condition
- When the Engine Start/Stop button
- When the shift lever is in D or R
position
- When the vehicle speed is not over
6 mph (10 km/h)
Push the parking assist system button
to the ON position to operate the
parking assist system. The indicator
in the button turns on.
To cancel the system, push the button
again. The indicator in the button
turns off.
• The system will operate automatically
every time the vehicle speed
is below 6 mph (10 km/h) with the
system switched on.
• When you move the shift lever to R
position with the system switched
off, the indicator in the button will
turn on and the system will operate
automatically regardless of button
status. However, if the vehicle
speed exceeds 12 mph (20 km/h)
when driving forward, the indicator
in the button will turn off. The system
will not automatically operate
again even if vehicle speed returns
to 6 mph (10 km/h).
To turn on the system, press the
parking assist system button.
• When more than two objects are
sensed at the same time, the closest
one will be recognized first.
