Quad pipe tips on a 2013 Rspec
scherkey52
Florida
Hello,
Has anyone found any quad pipes tips that fit the cutout in the bumper?
Something like the Nissan Maxima 2020 or any newer Mercedes amg for example.
That seems to be easy to find for any other vehicle.
Closest I can think of would be from a sonata sport or azura.. but even then I doubt it would be a direct fit
I just popped(didnt cut anything) mine out and have actual quad tips lol I'm sure you can find squared off quad tips and have them welded to sit flush in the opening
How did you "pop" it out?
I have the stock exhaust. Do you know what the size of the pipe is? Its oval shaped.
Where did you get the rear diffuser?
I believe stock piping is either 2" or 2.25" my magnaflow catback exhaust is 2.5
And you wouldnt need an oval shaped pipe that tip would be cut off and new tips would be welded on in its place. The inserts are held in by 2 screws each that are easily accessible from behind the bumper once mufflers are removed. I think its a 10 or 12mm bolt size. I can show you a picture of the insert when I get home.
What's the size of the tips you used to be able to fit it in the insert without cutting anything?
Uhh I went with 3.5" quads
