FOR SALE: Genesis Weathertech front Mats
Ranuve
Black laser fitted Weathertech mats from my 2015 Genesis. Will fit 2014 through current Genesis/G80. Excellent condition $55. Solon Ohio (near Cleveland)
Tempting... be interested to see a few more detailed (up close) photos of their condition.
Would you consider shipping if I provided label?
The right passenger site is little bit different for RWD and AWD. I had to buy a new set for my '18 AWD
Will these mats fit a 2016 Genesis 3.8 AWD vehicle?
If OP's car is RWD, then it won't. I mean, the drivers side is perfect fit, but the passenger isn't.
Sure. I can get more pictures. Yes I can ship. Is your car AWD?
Unfortunately not AWD. I did not realize that made a difference until dareckibmw pointed that small but significant detail out. So I will have to pass.
However, I appreciate your willingness to ship.
I think I still have mine somewhere in the garage, I'll check it out in the morning and let you know if you're interested.
Once again......mine are for RWD '15- '19?
Yes they should. You can go to the Weatertech site if you want to be sure. 2015 and 2016 are identical.
Hi, I just checked and the part number is the same for the 2015 and 2016 AWD Genesis. 447381
Certainly interested. Thanks for the offer.
I'll post some pics to highlight the difference between AWD and RWD, if OP doesn't mind.
Ok....driver's side are identical, so I'm not posting any pictures.
This is only passenger side, that is different in RWD and AWD (on top) as you can see, the left hole is moved away from the edge, towards the center, therefore the holes will not match with the hooks/pegs and the left edge curve is different as well and it will not fit right against the wall.
Ragillmore: are you still interested int the mats? They will fit your 2016 AWD.
I will have to pass as there is a difference between AWD and RWD I attached the two different part numbers from the weathertech website. You can also see the difference in the pictures of the front passenger side liner. Thanks for the offer though.
If these are still available, I am interested. 2016 awd.
Confusing, see post 7,8,9 and 16.
