fstephens
Check to see if the Parking Assist sensors are malfunctioning, as mine were. Middle front sensor was showing something there, even after cleaning it, when there was nothing there; it just stayed active. Some sensors were not activating, when Parking Assist was manually turned off/on. When all sensors were showing off, while the car was turned on, there was no dead battery the next day. This was actually a PROBLEM 2 causing dead battery, too. The small plunger, driver side attached to hood, that turns stuff off for the shutdown, associated with the car theft/security system, was also missing; part was less than a dollar and an associate at the dealer, attached it when I purchased it - appeared to simply plug in to the hood. #3: also have the fuse boxes checked to make sure a fuse is not inserted into port that should be empty; this can activate things that should be shut down when the engine is stopped.
