High Gas Consumption in city driving!
Bedford007
A year ago, my 2010 Genesis sedan 3.8L, went from a nice 10L/100Km to 14L/100Km. I had a dealer look into it and $2500 later ended up with problem not resolved. The dealers approach was hit and miss approach:
- Lets replace the spark plus
- Lets replace fuel injectors
- lets replace the Mass Air Flow Sensor
All of the above did nothing to rectify the problem. I did give a piece of my mind to the dealer in that they should be brain storming the problem and not trial and error approach which in essence is a money grab.
Anyone else experience this type of increase in gas consumption?
So 23mpg to 17mpg in the city. 23 seems high for city, but 17 doesn't seem all that low even for a V6. I get 18 in my 4.6 most tanks, but if I get heavy with my right foot it can easily be 14-15.
So the dealer fired the Parts Cannon, eh?
How many miles on the car?
Q&A time... Diagnostics:
CEL on? ...which codes?
Did they do a compression test?
Replace fuel filter or air filter?
What about O2 sensors?
What does the long term fuel trim show? If it's heavy-rich, then it's throwing extra fuel at a what the ECU sensed to be a lean condition. Most often caused by intake manifold fuel leak or dirty/bad throttle plate or throttle controller. Did they bother to check any of this? If the LTFT is close to zero (less than +/-5%) then the problem not likely MAF or intake, but you never know because sometimes a dealer can unknowingly replace a bad MAF with another bad MAF.... it happens.
Fuel:
Same time of year? Same part of the country? Did the fuel regulations change driving a change in fuel formulation? (summer/winter fuels in the USA often affect mileage).
Tires:
Did you change them? +/-10% is possible depending on rolling resistance.
Pro tip: you can log the LTFT or watch in real time yourself with Torque Pro App for $5 plus a $15 bluetooth OBD2 reader.
Fuel:
Tires:
You are little too technical for me.
No compression test.
Changed tires from winter to summer - no change
Fuel and air filter replaced. (BTW: high manufested after air filter replaced, that is why I thought it could be MAF)
Same time of year (Fall)
CEL, LTFT ... all too technical :)
I had a friend hook up his laptop to ODB port while I drove; and he said all seems to be OK at low and high speeds.
Read this:
Fuel trim: How it works and how to make it work for you - Automotive Service Professional
